Quote:
I have a stash of delvac 15w40 and rotella 10w30 that I need to use up. I'm thinking of mixing it from fear of cat poison. yes, it will be used in an oil burner. 1 qt/3k miles
Well the company I used to work for used Delo 400 in their cars , service vans As well as their forklifts ,sweepers compressors The compressor as well as the engines to run them, They would pass smog with out any problems. That makes around 40 Ford vans some with the ohc engines As well as the owners Vette and Mercedes 10 company cars.Quote:
Quote:
So far there is a 5 year old Suzuki Esteem with 1.3L aluminum block engine which has been fed on HDEO like Delvac Super or Delo 400, most the later, the engine has 264000 miles on clock, very little oil consumption and guess what, no catalytic converter damage, passes emissions with flying colors.
Wow...sample size of one...very scientific.
Use 10w/30Quote:
Rotella 15w-40 has a pour point of -40 F so would this be good for use down to about 0 F? I'd like to use 15w-40 'year 'round but I'm concerned in the winter as it occasionally gets down to about 0 or a few degrees below. With a pour pioint of -40 I'm think I might be OK--thoughts?
One of the major advantages of an overhead cam engine especially a 4 valve per cyl is lower overall valve spring pressure.Quote:
I would think that any SM rated oil would not cause any additional harm to catalytic coverters when compared to regular SM rated gas oils (ie 5w30/10w30). These HDEO oils are fleet oils, designed to use across a broad range of engines. I would think the only downside would be a decrease in fuel economy. However most "fleet" vehicles are run hard with few cold starts, so that may not be an issue.
I've contemplated trying Delo 15w40 in my Mazda DOHC V6 due to the fact it has a solid lifter set-up and it tends to be a bit noisey at operating temps with 5w30 and 10w30. The HDEO oils, even in 15w40, seem to have superior cold weather capabilities and look really good on paper.
There always has to be some oil burning . It is nice when the oil burning is microscopic.Quote:
btw, sorry for dumb question.. how does the zddp reach the cat if there is no oil burning?
