I've used Rotella in our 97 Saturn (130,000 miles) as an oil consumption cutter. Both the 5W40 "syn" and the 15W40 "regular" seem to work really well, and at a good price.
Quote:
Using HDEO in gasoline engines will not hurt the O2 sensors nor the catalytic converter. These oils are rated SL for use in gasoline engines, so I can't understand why someone would think they'd hurt anything.
Quote:
I remember Japanese manufactures being worried about SM rated oil protecting adequately.
Quote:
Detergents also appear to effect the "ZDDP" performance so not clear as to the benfits when not required.
Off topic
http://www.swri.org/4org/d08/GasTests/IIIFtest/default.htm
http://www.swri.org/4org/d08/GasTests/IIIGtest/default.htm
Quote:
The valve wear sequence tests are different and so not readily comparable- that's where there is room for argument.
Quote:
The Sequence III is a high speed and temp simulation while the Seq. IV is low speed and T. SM reduced both allowable P and Seq. IV cam wear over SL, so the specs predict an SM product may offer better performance around town despite reduced P.
Quote:
The API categories after all are meant only as a one size fits all, fit for purpose minimum standard.
Quote:
If I knew how to link posts I would search Olympic's 24K mile OCI results for you 427Z06. My point is not just for sake of saving money, 24K OCI with excellent wear metal results says all I haved to hear on HDEOs use in gassers. Last I heard I think Olympic figured he could have pushed the miles further based on analysis. He also used this oil in a GM gasser mini van with great success on long OCIs.
Quote:
So far there is a 5 year old Suzuki Esteem with 1.3L aluminum block engine which has been fed on HDEO like Delvac Super or Delo 400, most the later, the engine has 264000 miles on clock, very little oil consumption and guess what, no catalytic converter damage, passes emissions with flying colors.
