Originally Posted By: dnewton3
Get several used oil analysis in your current pattern (it will take time; be patient). Also, pull a valve cover or two a few times and take pictures. Then, swap oils and repeat the process. I think you'll find that, while premium products certainly are great products and have their good applications, they are not needed for normal situations. And everything you've told us so far is that you're "normal" in your use and maintenance needs.
Who do you recommend for doing the used oil analysis. You can PM me if necessary.
