HD 360 and Amsoil sample.
PAO based is at least 85% by volume.
performance and UOA is the only deciding factor
if a lubricant will last in an extreme enviroment.
petroleum based synthetics will always fail first above 350 degrees.
PAO based oils will only start to fail at 100 dgrees more temperature.
why pay the same price for less temperature protection
...why pay the same price for less temperature protection?
I agree with that--but I have a different perspective on it. There are good group III oils on the market that do a fantastic job of mitigating wear metals and corrosion--even in very hot engines.
I think that the generally elevated metal counts in group IV and V synthetic used oil analysis that we see (and please don't treat this as personal opinion, it's a FACT--read the used oil analysis here) are more owing to corrosion than to the PAO's ability to lubricate.
While it is true that the group IV and V oils will fare better in extremely hot environments, this is overkill. Take a look at this used oil analysis which I did a couple years back: http://theoildrop.server101.com/forums/s...true#Post714572
You will see that the group III Havoline PCMO oil did extremely well. The engine of my bike got so hot during that OCI that it actually didn't want to stop running when I switched it off one day. (Had to put it in gear and kill it by dumping the clutch). And there were other 100 degree riding days during that OCI.
So the point is, if the group III Havoline oil can perform this well, and turn in a used oil analysis which beats virtually every other synthetic oil Harley used oil analysis on the board, we have reason to believe that a group III oil can endure some extremely hot conditions and still work very well.
Now. The other side of the coin is this: What about the corrosion/rust inhibiting qualities of the oil you're putting in your engine? Are you willing to accept an excess amount of rusting in trade for 50 or 100 degrees of high temperature protection that you won't ever need?
Realize that by the time your engine has gotten hot enough to need a group IV oil to save it, it's TOAST ANYWAY!!
None of us know how much group III (if any) is in this Amsoil motorcycle oil. I think a STRONG case can be made for a significant group III content, based on reasons I've already stated. I'm not knocking Amsoil here--I'm actually commending them for producing a product which has turned in a better motorcycle used oil analysis of any previous Amsoil product. I just think that they've probably used a fair amount of petroleum oil to do it.
Dan
I wish oil performance in various areas followed such simple and consistent rules based on base oil(s) and additive ingredients. It would make choosing motor oils so much easier for us. It would also make it easier for formulators to achieve what they want without as many interations of blending/testing/blending/testing...
