Many times the placebo effect takes hold.
For instance...unless you have a hydraulic clutch, the oil shouldn't have anything to do with the pressure the clutch lever has. Even with a hydro-clutch, the action will only change if you change out the clutch sump to a lighter oil.
I suspect the "feel" of other mechanical issues is also effected this way.
