In the older US systems, the sight glass should have a solid flow of refrigerant with no bubbles or visible movement... Only when the compressor cycles should you see some flow/bubbles...
The above in the older systems indicated low charge, causing the evaporator to freeze, blocking air flow through it... With system off the evaporator thaws, normal operation returns and the cycle repeats...
If it has a fresh air setting, see if you can thaw it in 5-10 minutes to restore operation...
