I am getting ready to order parts for an AC Fix on my 2003 Suburban.
This is the dealer part for the orifice valve:
OE Orifice Valve
This is another on Rock Auto.
Variable Orifice Valve
It states:
Features & Benefits
Benefits of a Premium Variable Orifice Valve (VOV)
A Premium Variable Orifice Valve (VOV) is designed to change outputs based on different operating conditions. This significantly improves A/C performance at low speeds and idle, by allowing more refrigerant to flow.
Is this worth considering or just stay with OE? I do have high ambient temperatures and troubles cooling at idle (But that could be because of other issues)
OE Orifice Valve
It states:
Features & Benefits
- Drop in replacement and upgrade to the standard Fixed Orifice Tube (FOT) - no further modification is required to the A/C system
- Increases A/C cooling performance at idle, low speed and hot climate situations
- Reduces A/C Compressor loading to help extend compressor life and improve fuel economy and emissions
