2012 Mazda 3 2.0 Skyactiv 6MT 167k
Between 60-70 degree weather, the A/C blows ambient air temp (65ish degrees) while on the freeway. At idle when that temp outside, it is reasonably cool, but not as cool as it should be.
When colder than 60 the a/c functons normally. When first started in the morning, and when in the 70s-80s outside it functions normally. Let the vehicle sit at idle in 75+ degrees yesterday, and no issues with cold (40-45 degree ) A/C temps.
Did a leak inspection. Found small leak at condenser/drier. Both are bare aluminum on this vehicle and showed corrosion from living near the coast. Replaced condenser, drier, o-rings, PAG46. Professional vacuum system and leave overnight-no leaks and recharge with exact weight/volume specified 134a-no change except even cooler air at idle and when hot/cold outside. Still very much "dead" in the 60-70 degree ambient temp range.
Manual A/C, no temp sensor on the dash/etc that would be a factor. Compressor cycles on for 12-16 seconds/off for 5-6 seconds when functioning normally. When malfunctioning seems to cycle on 5-6 seconds and off for a similar period of time.
At idle, high side PSI is the correct 2.2 times ambient air, low side ranges from 25-45 PSI, triggering the compressor on/off at both respective ends of that range
When the system is off, it takes 10 minutes for the low side and high side pressures to equalize. I'm reading this may or may not be too long, depending on the vehicle.
Looking at a bad expansion valve? In that temp range maybe the valve is not opeining all the way, shutting off the compressor prematurely and then taking several seconds to recover, hence warm air?
Weak compressor? At speed slipping and not charging adequately or not building pressure quickly enough after being commanded off/on by the pressure switch due to worn internals? Took it for a "spirited" drive at 75 deg yesterday and the A/C funtioned perfectly.
Fan controller? Fan seems to come on normally in tandem with the compressor clutch.
Any one ever experianced anything like this?
