Originally Posted By: Brad_C
Originally Posted By: badtlc
One problem I have run into with doing that is using recirc only causes the vents to smell badly very quickly. Not sure why but I have to use fresh air regularly to prevent something from causing that smell buildup in the vents.
Lay off the beans.
But seriously, there should be *less* moisture in the system after a long run on recirc, so something else is going on.
It creates that smelly sock smell. I agree it seems anti-intuitive that increasing moisture doesn't make it worse but I think it just has to do with getting fresh air through there and not really the moisture content.
It might matter more that I park with the fresh air vent open and not in recirc mode since that is when the air really sits. I haven't tested that theory yet but I will now that I think about it. When I was getting those problems, I think was parking with everything still in recirc mode overnight.
Lay off the beans.
