Ah, Ok, I understand your point, yes, to each his own if one decides to step outside of what Harley recommends in your owners manual. I do understand what you are saying regarding the primary plus.
Only 2 fluids recommended for 2014 HD RK Transmissions.
For me personally, if they do away with Primary+ I will use a 20/50 oil in the transmission and primary. Harley does with their syn 3 and the Syn 3 is a GL1 oil vs the GL4 or 5 people are putting in (gear lube) At least with 20/50 oil your in the same class of lubricants.
I also found on Mobil 1 site regarding the transmission to use what the owners manual says, I think since Harley Davidson uses 20/50 engine oil in the transmission you will be good to go vs. gear lube ....
"These products will help provide excellent performance in motorcycle engines that are designed with a common engine/transmission lubrication system or where the engine lubrication system is separate from the transmission system. In the case of the latter, follow the manufacturer's recommendation for the type of fluid to be used in the transmission. "
Mobil 1 site
Mobil 1 site
