Harley Davidson Syn3
Irvine, CA
Good Evening Board,
I was reviewing my HD Catalog, and Harley says their Syn3 oil is a true synthetic, PAO/Ester, and not a "Highly Refined Group III."
I am thinking it must be true, or else this is false advertising?
Thoughts?
RevRider
Yeah, they would be open for false advertising lawsuit if it wasn't true. Doubt Harley wants to put themselves into that position.
ZeeOSix, that's what I would say also. So, from a price point of $12.95/quart for PAO/Ester based oil, as compared to other PAO/Ester products, the HD doesn't really seem overpriced to me.
HD Syn 3 used to be a blend and made by CITGO. I used in a pinch back when I owned my 08 FLHR. I'm sure it's quality oil since many riders use in the "3" holes and have rode many miles with no issues.
I still use Havoline 20W-50 from the stash. 10 years now. No issues. Sporty runs like a top, year after year.
Nothing wrong with Syn3 except the price. My .02.
Oil Analysis proves that any of the group products will meet or exceed your mileage
expectations because they all strive to deliver pure uniform molecules...
Refining means removing less desirable elements from petroleum until
what's left is mostly higher-performing molecular structures. Waxy
stuff had to go because it made oil congeal at winter temperatures.
Aromatics had to go because they lost viscosity too rapidly when hot.
Unsaturates had to go because they were vulnerable to heat-driven
gumming and sludging. And so on.
Group I: Petroleum oil containing 10-30 percent aromatics.
Group II: Hydrotreated mineral oils. Hydrotreating removes compounds
of oxygen, nitrogen, sulfur, chlorine, and metals.
Group III: Severely hydrocracked oils, the extensively reformed
"synthesized hydrocarbon oils" of today. Hydrocracking converts heavy
oils into lighter fractions by saturation, breaking large molecules
into smaller ones and creating from the fragments desired isomers.
Single-pass isomerization can boost the Viscosity Index (VI) of a
Group III base stock by 30 percent. VI indicates the rate at which an
oil's viscosity decreases as temperature increases in roughly the
range between cold and hot engine temperatures. The higher the number,
the better the oil covers the range of temperatures.
Group IV: The dominant automotive synthetic today is PAO
(Polyalphaolefin) + AN (Alkylated Naphthalene) + diesters, as found in
synthetic engine oils like Mobil 1. PAO delivers exceptional VI and
low pour point, while its tendency to shrink seals are corrected by
added AN and diesters. The PAO itself is synthesized by polymerizing
simple gas molecules derived from natural gas, and then connecting
these short hydrocarbon chains to form comb like structures.
Group V: Esters, polyglycols, silicones, neopentyl polyol esters, and
others, which are synthetic or chemically engineered oils not falling
into previous groups. Many are familiar to bike racers of the 1970s
through 1990s because they have been the basis of two-stroke racing
oils. Some of these oils can have higher VI, oxidation resistance, and
resistance to thermal breakdown than do PAO-based synthetics. R&D
never ceases in the chemical industry.
[Linked Image]
[Linked Image]
"Group IV: The dominant automotive synthetic today is PAO
synthetic engine oils like Mobil 1."
How old is that information? I don't think many automotive synthetics are using Group IV these days compared to some years ago.
I'd agree with that, pretty much any brand synthetic you find on the shelf at Walmart or auto store is a group III. Simply highly refined conventional oil from the same hole in the ground. I think that has been said over and over on BITOG, but color me stupid, maybe I don't know a thing.
Group IV oils must be fully made from ethylene, they do not come from any oil as we know it that comes from the ground. With that said, does it have to be a 100% group IV or can there be a small group IV component and it gets considered a group IV and covers their butt?
I run Syn3 in my Sporty...as hot as it runs (air cooled, and I've seen 280 degree oil), it probably helps.
Originally Posted by RevRider
Good Evening Board,
Thoughts?
RevRider
Couldn't find the actual MSDS for the life of me, but I found this in an HD forum (https://www.hdforums.com/forum/oil-and-oil-related-topics/1181701-syn-3-in-all-3-not-a-fan-3.html)
Looks like it's 50%-70% Group IV. Again, second hand source, so reliability may be suspect.
Thank you for the responses.
I do believe, from the research I've done, and willing to stand corrected if other information is presented, that just about all auto oils claiming synthetic are really just Group III. Some of the boutique oils use PAO, and I think only M1 uses PAO in a couple of their products; Annual Change and Extended Performance.
Mobil 1 MC specific oils are speculated to have something more/better than group III synthetic simply because they rarely shear out of grade and shift quality stays consistent in a shared sump. My experience with both of them for 5000 miles each confirms this. One peculiar characteristic of the 20w50 Vtwin oil in air-cooled twins is to thicken on longer oci's as shown on at least a few reports on this forum
For the money, Mobil 1 MC specific oils at $10 a quart that go 5000 miles and do not lose shift quality get the nod. YMMV.
Good Evening Board,
Thoughts?
RevRider
Wow, great post, I had no idea. Not a bad price then.
Yes, its true and very very few oils are PAO/Ester true synthetic. Most are made of oil, other then price, not sure if it matters as far as wear.
Great post.
Good Evening Alarmguy,
When I consider the PAO/Ester options I am thinking for motorcycles they are:
1. Red Line
2. Spectro
3. Maxim
4. Torco
5. Bel Ray
Perhaps a few more.
I believe all of them are more expensive than Harley's Syn3. I'm not drinking the Harley cool-aid, but their price for a real, true, synthetic oil is decent.
I've been using Valvoline in my 2014 Road King, does a good job, I've posted my UOA's, but I am really thinking about going back to using HD's oil since it is really a legit Group IV/V oil.
Out of principle, it ticks me off that Group III oils are classified as synthetic. I don't doubt they are good products, will do a good job, but they are not what they purport to be, all sanctioned by legal twistings - thank you British Petroleum/Castro.
Just one oilhead's opinion.
RevRider
At the end of the 1990s, Mobil asked that Castrol be required to stop
calling its petroleum-originated engineered oil "synthetic." Castrol
argued that the term synthetic could perfectly well describe oil
molecules whose shape had been fundamentally altered by chemical
engineering. In a 1999 decision by the Better Business Bureau's
national advertising department, chemically engineered and reshaped
petroleum-based oils can be called synthetic. This is because what is
important is that, in both cases, desirable, higher-performing
structures have been created, not just separated out of petroleum as
cream is separated from milk.
My understanding is different on that.
The molecule shape on group 3 oils is not altered. They are selected based upon uniformity of size. Group 3 oils are the same oil that comes out of the same hole in the ground as conventional oil. However molecules of uniform size are separated out from the rest, which ultimately was considered enough manipulation to be called synthetic.
I see your lengthy post about the different oils on the previous page. It does say that group 3 oils are hydrocracked which is not my understanding (that it involves that much work to make a group 3). However I may have learned something if that is the case.
Harley's oil is expensive because of their mfg process. They hire guys to sit by a large tanks, and pick out all the large and small molecules from the oil. This leaves only the square molecules which are then packaged for use in Harley's. This is what creates Harley's unique sound not found in other brands.,,
