Originally Posted By: Vikas
Here is an easy way to check if your 3/8 is working or not.
Get 1/2" and 3/8" socket which will work on your wheel nut (or one socket and one 1/2/->3/8 reducer). Loosen one nut and tighten it back to 40 ft-lb using your 1/2" torque wrench. Set your 3/8" torque wrench to 45 ft-lb and see if the nut now moves slightly with your 3/8" torque wrench. Set 3/8" to 60 ft-lb and tighten the bolt. Now set 1/2" to 65 ft-lb and use that to make sure the nut moves slightly. Put it back to 80 ft-lb and you are done. Now you have verified that your 3/8 works at least as good as 1/2" and can be relied upon (until you drop it
Use similar technique to verify 1/4" torque wrench. You are making sure that they are withing ballpark and more importantly you will get a feeling of how they click. Also you have to remember that the clicking is very different at low the end of the scale as compared to mid or high and is easy to miss.
I love talking about the torque wrenches; currently HF has all three on sale for $9.99
You could just pick up one of these: http://www.harborfreight.com/catalogsearch/result/?q=digital torque wrench
I pretty impressed with it. It looks cheesy in the pic but it's well made and was/is very accurate.
By the way, the HF ¼ and ½ tq wrenches I have are well within the stated 4%.
I do hate that they are difficult to read but for $9ish bucks each they are are a tremendous value
