Hailstorm causes major damage to nose, cockpit windows of Austrian Airlines plane
https://nypost.com/2024/06/10/world...e-cockpit-windows-of-austrian-airlines-plane/
Could this have been avoided / prevented by the pilots ?
“Not visible on radar” - so, no.Hailstorm causes major damage to nose, cockpit windows of Austrian Airlines plane
Radomes get bang and beaten quite often but commercial airliner windshields are truly an engineering marvel.
That little A320 got hammered.
I assume the plane/engines have to go through a pretty thorough inspection for damage? The rotor blades must have got hammered too.
Evidently it's not like when you're on the ground and you can see precip off in the distance? A pilot won't be able to see severe weather until they're too close to avoid it?“Not visible on radar” - so, no.
Can’t avoid what you can’t see.
Windshields aren't that complicated. It's a glass-plastic sandwich. Glass for scratch resistance and plastic for impact resistance. Not much different than an auto windshield. But those can get pretty messed up too if the glass layer cracks.
Yes, and no. When you’re flying in the clouds, it’s hard to see other clouds. On the ground, below the clouds, you can see lots of clouds.Evidently it's not like when you're on the ground and you can see precip off in the distance? A pilot won't be able to see severe weather until they're too close to avoid it?
Ever been in fog so thick that you can’t see the center line of the road?
