I thought I'd post some pics with the current project. Many people don't have a concept of how these large inspections go on Gulfstream Jets.
The horizontal stabilizer had some corrosion on the lower skin. Gulfstream chose to replace the entire skin with a new and improved skin. It's about 1/4 inch thick at the root, and very, very well made. Quite a process, takes about 4 months. The rivets are drilled out, then a small, high pressure air bag is inserted and pressurized. This breaks the glue bond between the ribs and the skin. It's very time consuming, and a bit risky too, as sometimes the rib breaks instead of the glue.
The first picture is the tail going back on this week. The other pictures are of the tail in various states of re-work. Remember, these models of Gulfstream aircraft fly at 51,000 feet, so they have a LOT of wing area. Even the tail is quite large.
