Vehicle: 1984 BMW 325e (E30)
Engine: 2.7L I6 (M20B27)
Vehicle Mileage: 125,868mi
OCI mileage: 3,355 miles
Oil: Castrol GTX 20W-50 (5 quarts)
Oil Filter: Bosch
Make up oil: none
Driving conditions: ~85/15 (Highway/City)
Refilled: Shell Rotella T6 5W-40
My thoughts: Other than the Copper showing above average, the others seem to be good. I am not too worried about the silicon as I had replaced the valve cover and oil pan gasket, and this is 2nd fill after it was replaced. Also, the silicon levels aren't that much higher than what is reported on my Toyotas. I think it is worth noting that Blackstone says the Universal Averages are based on 3,200mi of use.
I was a little worried about fuel dilution as it seems to run a tad rich, and sometimes I think I can smell a hint of gas when I am checking the oil. I am glad the report showed low fuel dilution.
I am looking to extend the OCI, so I can just rack up the miles on this commuter, so I settled on the Shell Rotella T6 5W-40. It seems to be one of the synthetics preferred over on the E30 forums, and I will see how it goes. I picked up some on sale. I am also considering Castrol Edge 0W-40 as the 5qt jug is similarly priced.
If anyone has other recommendations, let me know. I am not really interested in Amsoil or Redline at this time, as I would like to be able to find the oil at the local parts store/WM.
Backstory: This is my first UOA on this vehicle. I purchased it back in May and have put almost 7k miles on it commuting across Houston (~120mi/day).
I had done 4 previous OCs in the 1st 3500miles to help clean up the motor, and I was troubleshooting a cracked oil pan from a rear-end collision. The 1st OC was right when I got the car home after I bought it, and the 2nd drain was to remove the fluorescent dye I used to find the crack in the oil pan to fight with the guy's insurance (hit me 1 week after I bought it). The 3rd was when I drained it to patch the crack with aluminum tape until my replacement pan came in, and the 4th was when I installed the new pan.
All the oil I had used so far has been Castrol GTX 20W50, and looks like from the window sticker, the PO used whatever 5W30 was available at the local lube shop.
