Originally Posted By: bmwhitman
I agree it's not the only factor to consider when buying oil but I was reading threads like GC 0w-30 is group IV while all other Castrol Syntec is Group III and therefore GC is better. I was considering on using Castrol Syntec 5w-40 but based on comments of group III is inferior to group IV, I was skeptical.
Again, look at the specs that GC meets. It meets some of the most stringent specs out there such as MB 229.5. That is what makes it a good oil, but only IF your engine mfg requires such specs.
If you have a Civic or a Corolla, I am not sure that GC is the best oil to use in it, despite GC meeting all those fancy specs. Do you see what I'm getting at? Start with your need and your specific application, then pick an oil that was designed for that application, not the other way around.
