quote:
Originally posted by ED P.:
What happens is that the glycol and additives will breakdown due to heat, which in turn becomes acidic, which creates an electricly charged solution which usually is attracted to the metals. In diesel engines for example, the liners normally become the first thing to spring a leak due to electrolsis, unlike a gas engine, it's usually the radiator.
The best ways to eliminate this is to watch the acidity levels of the fluid by using a PH strip, get from some swimming pool chemical supply, walmart may also carry it., check for neutral balance of 7. If too much acidity, you can either treat it or better yet, flush and change the fluid.
I use the schaeffers Clean and Cool myself which maintains and neutralizes the acids as well it breaks the ionic water tension so that it makes the water wetter giving it a better cooling effectivness . Redline appears to have a water wetter which is simular to the Clean and Cool which breaks the ionic tension but not sure if it neutralizes acids like schaeffers does. I suspect it also will cost more as most of their products do compared to schaeffers.
Ed P.,
I'm really interested in this schaeffer product, but how do I test for all 3 coolant properties? Does schaeffer or somebody else sell test kits?
From
www.schaefferoil.com/data/258.htm
Test for pH
pH should be between 9.0-10.5
If below 9.0, remove all of the coolant and dispose of properly. Flush and replace with a new 50/50 antifreeze/water solution.
If above 10.5, remove some coolant and replace with a 50/50 antifreeze/water solution.
Test for Nitrate Level
Nitrate level should be 300-1200ppm
If above 1200ppm, remove some coolant and add a 50/50 mixture of antifreeze/water.
If below 300ppm, add 1 pint of Clean & Cool to each 8 gallons of cooling system capacity.
Test for Molybdate Level
Molybdate level should be 400-2000ppm
If below 400ppm, add 1 pint of Clean & Cool to each 8 gallons of cooling system capacity. (If Clean & Cool has already been added to raise the nitrate levels DO NOT add any additional Clean & Cool.)
If above 2000ppm, remove some coolant and add a 50/50 mixture of antifreeze/water then recheck both the nitrate and molybdate levels.
[ February 23, 2003, 04:49 PM: Message edited by: jjbula ]
