I am making a list and plan on all of this. I do understand it's more than just engine mounts. No worries
He's not crazy, he's just mad. The username should have tipped you off.You're CRAZY.
This illustrates the true nature of the situation.He's planning on swapping an FWD (traverse) engine into a 4WD (longitudinal) vehicle. The driveshaft will be the least of his worries, He won't be able to use the transaxle from the donor vehicle, he'll need to retain the OEM transmission, because it will be mated to the transfer case. He'll need to rig something up to adapt the Jeep transmission to the Audi engine, the details of which I got into a bit in my post.
My picture above your post was exactly that.If you could fit a 300 CID Ford straight 6 cylinder in it then, you would have something.
Same for the Honda 5 cylinder in the Acura VigorI have to agree about that 5cyl VW sound. Sounds like a V10. Had a Audi GT coupe with the 5CYL. That was a sweet motor.
The odessey does not see rpms above 2,000 , so a thick oil is not a good idea in it, maybe a 5w30 or 5w40 but 5w20 has been working since brand new.Vw Jetta 2011 2.5 - 15w40 (totaled ): ) , Vw Jetta 2014 2.0 - 15w40 , 2020 toyota camry - 20w50 , Honda odessey 2006 - 5w20, Panzerkampfwagen VI Ausf E - 10w30 Motul VW 501.00 spec, still in warranty.
^^Looking at your sig I see you're a thickie. How come a thin W-20 in the Oddy?
Yep, I can only use jeep wrangler transmission, though mating it into the transmission will be a big challengeHe's planning on swapping an FWD (traverse) engine into a 4WD (longitudinal) vehicle. The driveshaft will be the least of his worries, He won't be able to use the transaxle from the donor vehicle, he'll need to retain the OEM transmission, because it will be mated to the transfer case. He'll need to rig something up to adapt the Jeep transmission to the Audi engine, the details of which I got into a bit in my post.
So, on a scale from 1-10, how well would you rank your expertise, experience and history of executing projects of this nature? With 1 being you've never done an engine swap period and 10 being you've done multiple engine swaps using equipment from different OEM's, including transitions from traverse to longitudinal and vice versa?Yep, I can only use jeep wrangler transmission, though mating it into the transmission will be a big challenge
an 8 , I put a ls1 engine into my dads old toyota sienna, couldnt do it traverse, so it was longitudinal, we had cut out the hood and the front bumper to fit this engine in, along with also making it rwd with a junk yard rear wheel drive axle.So, on a scale from 1-10, how well would you rank your expertise, experience and history of executing projects of this nature? With 1 being you've never done an engine swap period and 10 being you've done multiple engine swaps using equipment from different OEM's, including transitions from traverse to longitudinal and vice versa?
Please post some pictures of this beast.an 8 , I put a ls1 engine into my dads old toyota sienna, couldnt do it traverse, so it was longitudinal, we had cut out the hood and the front bumper to fit this engine in, along with also making it rwd with a junk yard rear wheel drive axle.
I helped my buddy put a bmw i6 in his chevy too.
I don't have pictures on my computer or phone, I will see if I have them laying around my house , this was 3 years ago when we did this.Please post some pictures of this beast.
Hmm.I don't have pictures on my computer or phone, I will see if I have them laying around my house , this was 3 years ago when we did this.
I'd like to see pics as well, not saying it didn't happen, but this IS the internet.an 8 , I put a ls1 engine into my dads old toyota sienna, couldnt do it traverse, so it was longitudinal, we had cut out the hood and the front bumper to fit this engine in, along with also making it rwd with a junk yard rear wheel drive axle.
