I'd like to shed some light on a previous discussion about putting grease/conductive grease on battery terminals.
First of all, Grease should never be considered. Period.
What is happening to our battery terminals is an oxidation problem-not a lubrication problem.
There are products available that are designed to inhibit oxidation on electrical terminals.
I have worked in various electrical fields from the rebuilding of starters and alternators, to rewinding electric motors and for the last 29 years I've been an electrician.
I have a Master Electrician license which is irrelevant in this discussion but I want you to know that I have some credibility.
What needs to be applied to our battery terminals is an Anti-Oxidant compound. There are several different types and many manufactureres.
Battery terminals differ slightly from manufacturer to manufacturer. Lead is the most common metal used in the US for top post batteries. I've seen Foreign (to US) manufacturers use a different alloy for their terminal clamp but from my limited experience, it really doesn't matter much the alloy used.
I have driven GM vehilces for over 45 years with the beloved side post batteries. I have had great success with using a product called Noalox, made by iDeal. It's made for terminating copper wires into aluminum terminals. Never a failed start when a small portion was used.
There is another product called Copper Cote, which is actually an anti-sieze compound, but it will do the same job but from my experience with it it will tend to thicken over time.
Please do your own research and find the type of anti-oxidant compound that give you the feel-goods, but PLEASE don't use grease on your electrical terminals.
As far as the torqing/over-torquing of your clamp style terminals, Observe the recommended specs. Having said that, If you can move the terminal with your hand (twist, turn, pull off) it's not tight enough and no anti-oxidant compound will help you. The terminals must be tight to conduct electricity properly.
I hope this will help some of you who are not clear on this issue, I want to help you.
