Originally Posted By: Jarlaxle
I'm sorry, you have my condolences. You are now the owner of a ticking time bomb with a $11,000+ fuel system design flaw and no warranty. Keep every fuel receipt, video record yourself draining the water separator every 5000 miles and keep what you drain out in a sealed, dated container, change the fuel filter every oil change using ONLY a dealer part, video record that, too, and keep the old filters.
I would not even CONSIDER replacing the fuel tank...it will reduce the already-slim chance Ford will cover a failed HPFP to exactly zero.
Unless you have read something on this matter that I have not. GM actually has a higher failure percentage out of the Bosch HPFP's than Ford does and the only way Ford has been denying claims is when water in fuel was found to be the cause. All in where you get your information I guess.
