It is, I like that so much better than flicking through tailcap brightness levels, and I have no need for the strobe.Is that the one with the rotary dial for brightness control?
With 1A current, lumen output must be around 400-500 lm, so not great, but definitely usable - comparable to a Convoy S2+ with 4-chips.Review:-
Cons:- Tailcap threads have no anodization, so no lockout by turning the tail cap
Included battery is only 1800 mAh
Pros:- Everything else! I can't find any other fault. 3 Normal modes with real memory. Hidden and difficult to accidentally reach blinky modes. Good beam, good color. 50mA/500mA/1000mA tailcap current. Square and lubed tailcap threads. Rear button press good quality. Flawless HA3 anodizing. Nice knurling. Charging cover is quite good. Built-in charger with red/green indicator. The cardbox box is good quality and has lanyard and spare o-rings in nice plastic bag.
I say overall quality is as good as a typical Convoy light, fair price for this would be about $25 shipped. I am still shocked that it has NOT gone unavailable yet.
Beam pattern is in between with the hybrid reflector; Osram chip has surprisingly good neutral tint rivaling expensive lights. I can not see any artifacts in the beam and if there is any green tint to edge, I can not see it. Even the glass must be high quality because even though there is no obvious anti-reflection coating tint to that glass, it behaves as if anti-reflective.With 1A current, lumen output must be around 400-500 lm, so not great, but definitely usable - comparable to a Convoy S2+ with 4-chips.
What is the beam pattern like? Flood? Throw? In-between?
What color is the output? Cool white? Neutral? Any green tint around the edges of the beam?
Thanks. Does it tail stand?Beam pattern is in between with the hybrid reflector; Osram chip has surprisingly good neutral tint rivaling expensive lights. I can not see any artifacts in the beam and if there is any green tint to edge, I can not see it. Even the glass must be high quality because even though there is no obvious anti-reflection coating tint to that glass, it behaves as if anti-reflective.
It does tail stand but mind you there is a rubber switch boot there but at least on my sample, that clears the tail cap edge but barely just by few hairs! The most difficult task was threading the lanyard in the two holes!Thanks. Does it tail stand?
You are right; the light on high is more about real 400-500 lumens but I still consider it a good dealI ordered 3, as 2, without prime, shipped, is nearly the same price as 3. One or 2 will be gifts.
My existing 18650 handheld light can be focused but has less than impressive output, and interface.
I've got a 14500 based light Sipik clones that were like 2 for 7$ slow boat, one failed, whose output and throw seems far superior, and use it much more, but mostly I use headlamps.
The Osram P8 chip says 310 lumens
https://www.topledlight.com/5w-osram-p8-white-high-power-led-dc-3v35v-350ma1500ma_p2401.html
I see you already asked on BLF. Maybe they'll have some ideas.How did PeetPen aka WuBen manage to do this?
I couldn't help it, i ordered one. Don't need it, but at that price!Ridiculously cheap; I just received mine and then I promptly ordered 3 more. Under $10 is bargain of the year, grab yours now
https://www.amazon.com/gp/product/B08P4QHC6J
OK, but what happens if you do wait?Because I took it out when it went green. I did not wait for hours after it went green.
Ugh, looks like parasitic drain is rather high. Gotta remember to unscrew the tail cap I guess. Not muggle friendly.If anyone's looking for a 21700 cell powered light, at under $26, this is a good deal:
https://www.amazon.com/dp/B07F2Y8PM7
Comes with a 5000mAh 21700 cell. XHP50.2 LED. Works as a power bank, too.
I'm thinking of grabbing one.
Good news! Kept for an hour after green charge complete indicator and it stayed at 4.20VOK, but what happens if you do wait?
Just because the original Wuben C3 with USB-C port had overcharging issues does not automatically mean that this PeetPen does as well.
I toss these types of no-name li-ion cells straight into trash bin, so no, I wouldn't ask for a new one, but I guess if you're going to be gifting it, then maybe. Do you have an analyzing charger to test discharge capacity?Should I complain and ask for a new battery?
