I'm starting to understand how to pick a good motor oil. You know what the typical figures mean and how pick the best (for me) of a given set of oils. Then what to look for in analysis to see that my chosen oil is up to the task.
What distinguises a great hydraulic fluid from a meets minimum requirments hydraulic fluid?
What should I look for in analysis of used hydraulic fluid?
My only use is in farm tractors. In farm tractors the hydraulic fluid is a combination fluid used for gearcase cooling, lubrication and for true hydraulic type uses.
Additionally everything on a tractor is subject to lots of dirt, vibration, constant high percentage power settings (its not uncommon for a tractor diesel to operate at 75 or 80% power for hours on end) and frequent shock loading.
