Has anyone have any experience with this product.
Gold Eagle: Oil System Flush
SPECS:
Proven technology that safely removes harmful sludge, varnish and gum deposits from engine without causing leaks
Helps free sticky valves and rings
Allows oil to circulate freely
Helps improve performance and extend engine life
Contains no kerosene or fuel oil
Safe to leave in crankcase if drain plug is not removable
Usage: Use every 3rd oil change, or every 9000 miles under extreme conditions. Ever 22,000 miles for normal.
Directions: Add entire contents through oil fill opening before changing your oil. Let engine idle to circulate oil (2-3minutes). Shut down engine and immediatly remove drain plug and drain dirty oi. Change oil filter and refill crankcase with new motor oil according to the manufacturer specifics.
Contains: Petroleum oil and ethylene glycol monobutyl ether.
I personally used ARX but thinking of running this on my sisters beater car that consumes oil..TIA
SPECS:
