Going back to 0w-20 for the winter
Rochester, MI, US, World
I have used 0w-20 for every OCI on the Carnival except the current one, where I used ESP 0w-30. My reasoning was: 1) the oil sump temps settle at 230F+ on the highway and 2) we drove to Florida this summer. We drive a LOT in the summer, especially this year. Lots of hot weather, long trips. All 'cold' starts are at 60f+ or near enough. Just wanted an extra buffer of protection whilst bombing down the highway/up a mountain in 90+ weather.
But in the winter, this vehicle gets driven far less. Lots of half mile 25mph trips to/from school, with errands around town. We use the van for volunteer work sometimes, where the oil will reach full temp for awhile. But the vehicle will spend most of its time putting around on trips 30 mins or less. In these conditions, fuel dilution will go up for sure, but since the oil won't get as hot and not nearly as often, I'm going back to 0w-20 in the winter. Now what to use... probably ESP 0w-20.
I don't see that as a reason to go back to a 20 seasonally.
Why not? I tend to like thicker oils, but a 20 grade at the temps I’ll usually be running in the winter will still be about as thick as the ESP 0w30 I have in there now at summer highway temps, given how we drive.
Love these posts. I towed this past year up to the highest city in the U.S., Leadville, Colorado (10,000 feet) pulling a 5,000 pound travel trailer in 90 degree heat using 0w20 in my 2023 Silverado (5.3). That's what the manual states-that's what it gets.
Don't think your mini van will see conditions like that-especially in your part of the U.S.
Doesn’t your truck’s oil run a lot cooler though? I can’t remember if it was your post or someone else’s, but I recall seeing that oil temps in this truck never got much above 200. Mine get above 240. That was my main determining factor in choosing viscosity. The engine is also high compression.
I’m looking at getting a ‘26 Carnival in the very near future(Labor Day sales). Based on a few threads about it on here, I was planning on running ESP 0w30 year round after the initial OCI with the 0w-20 FF.
Based on your details, it seems like a fine plan for winter.
What's the oils operating temperature?
If you know the oil doesn't get above 90c during the winter then 20w would be a fine choice.
That ACEA ESP 0w30 with its high HTHS is nothing like an AFE 0W-30.
Why not a good 0w30 ILSAC lube for those Michigan winters, then you will have those uncurled VM for when you take longer trips with a hot sump. The poor engine will get confused being fed a Golden Honey then Weasle wee in the Wintertime. I can hear it exclaiming, " What did I do wrong to deserve this, this injustice?!"
Does the manual really recommend using 20wt for pulling huge trailers up mountains in summer?
I'd bet it does not.
