GM GoodWrench Bulk
CA
Had the oil changed on my Saturn at an ancient Chevy dealership. Their bulk oil is GM Goodwrench 5w30, which I assume is made by Mobil since the oil change sticker they installed says Mobil on it and I found a Mobil powerpoint describing the Goodwrench bulk oil program.
So, which Mobil oil is the Goodwrench oil equivalent to? Clean 5000?
In Canada, Mobil used to have a 'Mobil Clean' oil that was bulk ONLY. Doesn't seem to be on their site anymore.
I'd imagine that Mobil has the same prduct in the US, and as EJ said, it's close to 'Superflo'..slightly less additives than 5k.
How did the service go?
Sounds like you balked at the Iffy Lube option....good for you.
Any oil at this point in that Saturn of yours will probably do just fine for your 3k runs.
