Originally Posted By: StevieC
Anyways... for the GM heads... Anyone get this P-Code before and know what it is?
I have heard everything from bad gas cap, to bad EVAP system to leaking vacuum hose on the top of the gas-tank etc.
Here you go: I know its hard to read here so if you need a better copy I can email it to you. But anyway - here you go:
xTooltipElement
Service Information
2004 Pontiac Sunfire | Cavalier, Sunfire (VIN J) Service Manual | Document ID: 1282976
DTC P0455
System Description
The control module tests the evaporative emission (EVAP) system for a large leak. The control module monitors the fuel tank pressure (FTP) sensor signal to determine the EVAP system vacuum level. When the conditions for running are met, the control module commands the EVAP canister purge solenoid valve OPEN and the EVAP canister vent solenoid valve CLOSED. This allows engine vacuum to enter the EVAP system. At a calibrated time, or vacuum level, the control module commands the EVAP canister purge solenoid valve closed, sealing the system, and monitors the FTP sensor input in order to determine the EVAP system vacuum level. If the system is unable to achieve the calibrated vacuum level, or the vacuum level decreases too rapidly, this DTC sets.
The following table illustrates the relationship between the ON and OFF states, and the OPEN or CLOSED states of the EVAP canister purge and vent solenoid valves.
Control Module Command
EVAP Canister Purge Solenoid Valve
EVAP Canister Vent Solenoid Valve
ON
Open
Closed
OFF
Closed
Open
Conditions for Running the DTC
• DTCs P0107, P0108, P0112, P0113, P0116, P0117, P0118, P0122, P0123, P0125, P0452, P0453 are not set.
• The engine is running.
• The ignition voltage is between 10-18 volts.
• The barometric pressure (BARO) is more than 75 kPa.
• The fuel level is between 15-85 percent.
• The engine coolant temperature (ECT) is between 4-30°C (39-86°F).
• The intake air temperature (IAT) is between 4-30°C (39-86°F).
• The start-up ECT and IAT are within 9°C (16°F) of each other.
• The vehicle speed sensor (VSS) is less than 121 km/h (75 mph).
Conditions For Setting the DTC
The EVAP system is not able to achieve or maintain vacuum during the diagnostic test.
Action Taken When the DTC Sets
• The control module illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
• The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
Conditions for Clearing the MIL/DTC
• The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
• A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
• A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
• Clear the MIL and the DTC with a scan tool.
Diagnostic Aids
• To help locate intermittent leaks, use the J 41413-200 Evaporative Emissions System Tester (EEST) to introduce smoke into the EVAP system. Move all EVAP components while observing smoke with the J 41413-SPT High Intensity White Light.
• A temporary blockage in the EVAP purge solenoid valve, purge pipe or EVAP canister could cause an intermittent condition. Inspect and repair any restriction in the EVAP system.
• To improve the visibility of the smoke exiting the EVAP system, observe the suspected leak area from different angles with the J 41413-SPT .
• Reviewing the Failure Records vehicle mileage since the diagnostic test last failed may help determine how often the condition that caused the DTC to be set occurs. This may assist in diagnosing the condition.
• A loose, missing, incorrect, or damaged fuel fill cap may cause this DTC to set.
• For intermittent conditions refer to Intermittent Conditions.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
This test verifies that the EVAP canister purge solenoid valve is electrically functional.
This test verifies that the EVAP canister vent solenoid valve is electrically functional.
Introducing smoke in 15 second intervals may allow smaller leak areas to be more noticeable. When the system is less pressurized, the smoke will sometimes escape in a more condensed manner.
This test verifies that the FTP sensor is accurate. An FTP sensor that does not correctly respond to vacuum, or pressure may cause this DTC to set.
Step
Action
Values
Yes
No
Schematic Reference: Engine Controls Schematics Evaporative Emissions Hose Routing Diagram
Connector End View Reference: Powertrain Control Module Connector End Views or Engine Controls Connector End Views
1
Did you perform the Diagnostic System Check-Engine Controls?
Go to Step 2
Go to Diagnostic System Check - Engine Controls
2
Inspect the Evaporative Emission (EVAP) System for the following conditions:
• A loose, missing, or damaged service port schrader valve
• A loose, incorrect, missing, or damaged fuel fill cap
• A damaged EVAP canister purge solenoid valve
Raise the vehicle on a hoist. Refer to Lifting and Jacking the Vehicle in General Information.
Inspect the EVAP system for the following conditions:
• Any disconnected, improperly routed, kinked, or damaged EVAP pipes and hoses
• A damaged EVAP canister vent solenoid valve or EVAP canister
Did you find and correct the condition?
Go to Step 38
Go to Step 3
3
Clear the DTCs with a scan tool.
Command the EVAP canister purge solenoid valve to 50 percent and back to 0 percent with a scan tool.
Do you hear or feel a clicking from the EVAP canister purge solenoid valve when it is commanded to 50 percent?
Go to Step 4
Go to Step 5
4
Command the EVAP canister vent solenoid valve ON and OFF with the scan tool.
Do you hear or feel a click as the EVAP canister vent solenoid valve is commanded ON and OFF?
Go to Step 9
Go to Step 7
5
Disconnect the EVAP canister purge solenoid valve.
Turn ON the ignition, with the engine OFF.
Connect a test lamp between the ignition 1 voltage circuit of the EVAP canister purge solenoid valve and a known good ground. Refer to Troubleshooting with a Test Lamp in Wiring Systems.
Does the test lamp illuminate?
Go to Step 6
Go to Step 29
6
Connect a test lamp between the ignition 1 voltage circuit of the EVAP canister purge solenoid valve and the control circuit of the EVAP canister purge solenoid valve. Refer to Circuit Testing in Wiring Systems.
Command the EVAP canister purge solenoid valve to 50 percent and then to 0 percent with a scan tool.
Does the test lamp illuminate or pulsate when the EVAP canister purge solenoid valve is commanded to 50 percent and turn OFF when the EVAP canister purge solenoid valve is commanded to 0 percent?
Go to Step 23
Go to Step 21
7
Disconnect the EVAP canister vent solenoid valve.
Connect a test lamp between the ignition 1 voltage circuit of the EVAP canister vent solenoid valve and a known good ground. Refer to Troubleshooting with a Test Lamp in Wiring Systems.
Go to Step 8
Go to Step 30
8
Connect a test lamp between the ignition 1 voltage circuit of the EVAP canister vent solenoid valve and the control circuit of the EVAP canister vent solenoid valve. Refer to Troubleshooting with a Test Lamp in Wiring Systems.
Command the EVAP canister vent solenoid valve ON, with a scan tool.
Go to Step 24
Go to Step 22
9
Important: Larger volume fuel tanks and/or those with lower fuel levels may require several minutes for the floating indicator to stabilize.
Turn OFF the ignition.
Connect the J 41413-200 Evaporative Emission System Tester (EEST) power supply clips to a known good 12-volt source.
Turn the nitrogen/smoke valve to nitrogen.
connect the nitrogen/smoke hose to the 0.5 mm (0.20 inch) test orifice on the bottom-front of the J 41413-200 .
Use the remote switch to activate the J 41413-200 .
Align the red flag on the flow meter with the floating indicator. Use the remote switch to de-activate the J 41413-200 .
Install the J 41415-40 Fuel Tank Cap Adapter to the fuel fill pipe.
Install the fuel fill cap to the J 41415-40 .
Remove the nitrogen/smoke hose from the test orifice and install the hose onto the J 41415-40 .
Command the EVAP canister vent solenoid valve closed with a scan tool.
Use the remote switch to introduce nitrogen and fill the EVAP System until the floating indicator stabilizes.
Compare the flow meter's stable floating indicator position to the red flag.
Is the floating indicator below the red flag?
Go to Step 12
Go to Step 10
10
Important: Ensure that the vehicle underbody temperature is similar to the ambient temperature and allow the surrounding air to stabilize before starting the diagnostic procedure. System flow will be less with higher temperatures.
Connect the J 41413-200 power supply clips to a known good 12-volt source.
Install the J 41415-40 to the fuel fill pipe.
Connect the fuel fill cap to the J 41415-40 .
Connect the J 41413-200 nitrogen/smoke supply hose to the J 41415-40 .
Turn the nitrogen/smoke valve on the J 41413-200 control panel to SMOKE.
Use the remote switch to introduce smoke into the EVAP system.
Use the J 41413-VLV EVAP Service Port Vent Fitting to open the EVAP service port.
Remove the J 41413-VLV once smoke is observed.
Continue to introduce smoke into the EVAP system for an additional 60 seconds.
Inspect the entire EVAP system for exiting smoke with the J 41413-SPT High Intensity White Light.
Continue to introduce smoke at 15 second intervals until the leak source has been located.
Did you locate and repair a leak source?
Go to Step 38
Go to Step 11
11
Disconnect the J 41415-40 from the fuel fill pipe.
Install the fuel fill cap to the fuel fill pipe.
Connect the J 41413-200 nitrogen/smoke supply hose to the EVAP service port.
Inspect the entire EVAP system for exiting smoke with the J 41413-SPT .
Go to Step 38
Go to Step 12
12
Use the remote switch to stop introducing smoke.
Connect the vehicle fuel fill cap to the J 41415-40 .
Command the EVAP canister vent solenoid valve open with a scan tool.
Compare the Fuel Tank Pressure Sensor parameter with a scan tool, to the J 41413-200 pressure/vacuum gauge.
Is the scan tool Fuel Tank Pressure Sensor parameter within the specified value of the J 41413-200 pressure/vacuum gauge.
1 in H2O
Go to Step 13
Go to Step 25
13
Seal the EVAP system using the EVAP Purge/Seal function with a scan tool.
Turn the nitrogen/smoke valve on the J 41413-200 control panel to NITROGEN.
Use the J 41413-200 to pressurize the EVAP system to the first specified value.
Is the Fuel Tank Pressure Sensor parameter more than the second specified value?
10 in H2O
5 in H2O
Go to Step 14
Go to Step 25
14
Use the remote switch to stop introducing nitrogen into the EVAP system.
Increase the EVAP canister purge solenoid valve to 100 percent.
Is the Fuel Tank Pressure Sensor parameter Less than the specified value?
1 in H2O
Go to Step 15
Go to Step 17
15
Connect the nitrogen/smoke hose to the EVAP service port.
Remove the J 41415-40 .
Start the engine.
Allow the engine to idle.
Use the purge/seal function to seal the system, with a scan tool.
Command the EVAP canister purge solenoid to 30 percent.
Observe the vacuum/pressure gauge on the J 41413-200 and the FTP parameter on the scan tool.
Allow the vacuum to increase on the gauge of the J 41413-200 , until it reaches approximately 16 inch H2O.
Is the FTP parameter on a scan tool within the specified value of the vacuum/pressure gauge on the J 41413-200 , until the vacuum reached the abort limit on a scan tool?
1 in H2O
Go to Step 16
Go to Step 25
16
Did the FTP parameter on a scan tool display more than the specified value?
3.2 V
Go to Diagnostic Aids
Go to Step 25
17
Disconnect the EVAP canister purge vacuum source from the EVAP canister purge solenoid valve.
Is the Fuel Tank Pressure Sensor parameter less than the specified value?
1 in H2O
Go to Step 28
Go to Step 18
18
Disconnect the EVAP canister purge pipe from the EVAP purge solenoid valve.
1 in H2O
Go to Step 33
Go to Step 19
19
Disconnect the EVAP purge pipe at the EVAP canister.
1 in H2O
Go to Step 31
Go to Step 20
20
Disconnect the EVAP vapor pipe at the EVAP canister.
1 in H2O
Go to Step 35
Go to Step 32
21
Test the control circuit of the EVAP canister purge solenoid valve for an open or for a short to voltage. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 38
Go to Step 27
22
Test the control circuit of the EVAP canister vent solenoid valve for an open or for a short to voltage. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 38
Go to Step 27
23
Test for an intermittent and for a poor connection at the EVAP canister purge solenoid valve. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairsin Wiring Systems.
Go to Step 38
Go to Step 33
24
Test for an intermittent and for a poor connection at the EVAP canister vent solenoid valve. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairsin Wiring Systems.
Go to Step 38
Go to Step 34
25
Test the low reference circuit of the FTP sensor for an open or high resistance. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 38
Go to Step 26
26
Test for an intermittent and for a poor connection at the FTP sensor. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 38
Go to Step 36
27
Test for an intermittent and for a poor connection at the control module. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 38
Go to Step 37
28
Repair the pinched or obstructed EVAP canister purge solenoid valve vacuum source.
Did you complete the repair?
Go to Step 38
29
Repair the open or short to ground in the ignition 1 voltage circuit of the EVAP canister purge solenoid valve. Refer to Wiring Repairs in Wiring Systems.
Replace the fuse as necessary.
Go to Step 38
30
Repair the open or short to ground in the ignition 1 voltage circuit of the EVAP canister vent solenoid valve. Refer to Wiring Repairs in Wiring Systems.
Go to Step 38
31
Repair the restriction in the EVAP purge pipe.
Go to Step 38
32
Repair the restriction in the EVAP vapor pipe.
Go to Step 38
33
Replace the EVAP canister purge solenoid valve. Refer to Evaporative Emission Canister Purge Solenoid Valve Replacement.
Did you complete the replacement?
Go to Step 38
34
Replace the EVAP canister vent solenoid valve. Refer to Evaporative Emission Canister Vent Solenoid Valve Replacement.
Go to Step 38
35
Replace the EVAP canister. Refer to Evaporative Emission Canister Replacement.
Go to Step 38
36
Replace the FTP sensor. Refer to Fuel Tank Pressure Sensor Replacement.
Go to Step 38
37
Replace the control module. Refer to Powertrain Control Module Replacement.
Go to Step 38
38
Connect the nitrogen/smoke hose to the 0.5 mm (0.20 inch) test orifice on the bottom-front of the J 41413-200 .
Go to Step 39
Go to Step 10
39
Observe the J 41413-200 pressure/vacuum gauge.
Increase the EVAP purge solenoid valve to 100 percent.
Does the pressure decrease?
Go to Step 40
Go to Step 17
40
Observe the fuel tank pressure sensor parameter with a scan tool.
Is the scan tool fuel tank pressure parameter within the specified value of the J 41413-200 pressure/vacuum gauge.
1 in H2O
Go to Step 41
Go to Step 25
41
Observe the Capture Info with a scan tool.
Are there any DTCs that have not been diagnosed?
Go to Diagnostic Trouble Code (DTC) List
System OK
© 2010 General Motors. All rights reserved.
