- Joined
- Mar 10, 2021
- Messages
- 250
Holy crap I take a break and come back to 6.2 problems - so I need to put 0W40 in my 5.3 as well?
Probably.
Two latest GM Bulletins mention some surface finish and dimensional issues as “root causes”. Hmmm nobody asked 5 why’s?Nothing much here. A secret US auto worker bad mouths a Mexico based manufacturer. Yawn. Let’s get those cranks mic’d and compare them to the specs. Otherwise it’s just finger pointing.
Pfft, I doubt at GM they get past the first why because the rest are killed by a "whys guy" looking for promotion LOL.Two latest GM Bulletins mention some surface finish and dimensional issues as “root causes”. Hmmm nobody asked 5 why’s?
If you haven’t already.Holy crap I take a break and come back to 6.2 problems - so I need to put 0W40 in my 5.3 as well?
agree ,its strange , with all the qc, iso 9000 yada yada , that goes on that something like this wasnt caught all this time ? im tool and die maker , working to .0001 inch on daily basis , i would almost believe there was some numbers wrong in there inspection process, or in the blueprints/ cad models that lead to this , maybe a corner rad on rod journal that was just out of spec ,Thinking out loud:
You think the U.S. engine assy post assembly spin test would "see" undersized crank pins on the press/volum plot. Maybe they are O.O.T. oversized. Then again the spin test should see at least an interference in the spin-up torque reading, though it would likely not see a 0.0005" diametrical clearance (which will be << 0.0003" running).
Incoming QC sampling should have caught a batch of out of tol. cranks. Before that, the outsource factory automated tools would have caught it right away if programmed properly. Did GM Autodesk Fusion send some funky #'s? Was it a pandemic world crash and burn all around? Starting to smell like a big ball drop.
It seems lately that everyone with a cell phone on a stick is a YT content provider. Sadly most of them wouldn’t have a clue what you are talking about.agree ,its strange , with all the qc, iso 9000 yada yada , that goes on that something like this wasnt caught all this time ? im tool and die maker , working to .0001 inch on daily basis , i would almost believe there was some numbers wrong in there inspection process, or in the blueprints/ cad models that lead to this , maybe a corner rad on rod journal that was just out of spec ,
we build cells and testers that go into auto assembly plants,there are a lot of protocals designed into these stations that idiot proff the whole process , so assemblers can dam near never get something wrong , i have been following some of this info coming out of forums ,and stuff , it would be very interesting to really find out , exactly what the the final culprit is ,and how it happened, but im sure that wont happen
Joke site?? What is actual source??
Caught a couple of stories that popped up.Joke site?? What is actual source??
Oh boy....haven't watched yet.
*Important Note!* I asked a GM powertrain engineer directly about this, who spends his life living and breathing modern performance engines (and specifically small block V8s). Regarding the L87 engine discussed in this video, I asked directly if today's modern, thinner engine oils are too thin for enabling reliability and cause concern of additional engine wear. His answer was a very concise "no." Testing validates this. I think if you watch this video fully (which is quite information dense!), you'll come to understand why. The blame does not lie on the engine oil, as the video breaks down in great detail. Did a lot of research for this one - hope you enjoy it!!
That’s kinda what I’ve always wondered. 5w30 across the powertrain board. Seemed to be the perfect balance of efficiency and viscosity for many years.What’s wrong with a good ole 5w30?
Nothing. Manufacturers went to 0W because it helps their fuel economy numbers. The warm-up cycle is where they lose a lot of efficiency. That and perhaps simplification since you can then recommend the same oil to both Alberta and Arizona.What’s wrong with a good ole 5w30?
Then give it a 0w30 if they’re that concernedNothing. Manufacturers went to 0W because it helps their fuel economy numbers. The warm-up cycle is where they lose a lot of efficiency. That and perhaps simplification since you can then recommend the same oil to both Alberta and Arizona.
So then 0w30 it and again, win all around.Nothing. Manufacturers went to 0W because it helps their fuel economy numbers. The warm-up cycle is where they lose a lot of efficiency. That and perhaps simplification since you can then recommend the same oil to both Alberta and Arizona.
I'm confused, do you mean in general or for this GM engine? They moved to a 40 because they need the higher HTHS a 30 would not provide.Then give it a 0w30 if they’re that concerned
