Because of the elliptical orbit of the connecting rod, the bearings self pump better than main bearings.
What are the rod and main bearing clearances in the 6.2L?
I’m blaming the low viscosity 0w20 being insufficient for the journal diameters, bearing clearances, rpm and low oil pressure delivered by the variable oil pump when the rpm is suddenly increased.
Why the last reason? Because it takes a few seconds for the oil pump to respond and deliver higher oil pressure to the engine. At 6,000 rpm, that’s 100 revolutions per second that the engine is operating with low oil pressure especially at the bearings furthest away from the pump.
What does thin oil have to do with it? The bearing leakage rate is higher in the bearing cavity, so the oil is squeezed out faster than it can be replaced.
I wouldn’t be surprised if the “Mexican” crankshaft had another half a thou bearing clearance which reduced MOFT below the threshold for 0w20.
So what is your logical fallacy? Run with the crowd on consensus, or appeal to a higher authority like a secret informant?
If I owned one of these engines, I wouldn’t have put 0w20 in it to begin with.
And anyone using 0w20 should as a precaution, switch to xW40 asap.
