GM 8 speed Transmission Flush
So I took the truck to the dealership and specifically requested a flush. Instead, they dropped the pan, replaced filter and gasket. They added 6qts back in. I asked the service writer if they used Mobil 1 LV. He had no idea. The part number on the invoice is 19421242, which is listed as discontinued AC Delco.
https://www.gmpartsgiant.com/parts/gm-fluid-a-trans-dexron-vi-acdelco-bulk-opt1-19421242.html
I went to the parts guy to have him check. He said it was Mobil 1 LV based on the bulk part number he cross-referenced. Other opinions from the FB group suggested it could be the older dex VI and not LV. Kind of a let's get rid of this old fluid type of thing....or, the part number is old and not matching.
I'm going to call tomorrow to confirm. If it turns out they put in older fluid I'm going to have them flush it out and put Mobil 1 LV in. You'd think by now they'd have this down being the headache that it was for them.
The exhaust crossover has to be dropped on these trucks to drop the pan. Just curious if they also had to charge for new bolts, gaskets, etc.
Do aftermarket pans with a drain plug exist? After that first ~30K pan drop and cleaning, I'd be good with just spills and fills from then on if you had a drain plug. Cooler line fluid exchanges being best obviously.
I do know in 2018+ Traverse world, 9T65 owners effected with TC shudder, have stopped it by changing over to M1 blue label Dex VI as well. Others have stopped it by just adding a bottle of LG red. Luckily my 2021 was smooth as butta when we bought it with 30K miles on it. I've done 3 spill/fills with "suitable for dex VI fluid use" just to get the darkened factory fluid out of there anyway.
I find my local dealership wants to do a full flush instead of just a pan drop alone. Weird.
For regular service the owners manual doesn’t even suggest a transmission service, ever. For severe service suggests a service ever 45,000 miles, and even so, it’s just a “ change fluid and filter” which is basically a pan drop. Sounds like a mechanic who doesn’t care what the service writer puts on the form.
View attachment 216924View attachment 216925
Yeah it's kind of weird actually. I requested flush, but they did a pan drop/filter/gasket change. I'm ok with that.
The service manager confirmed with the tech that the right fluid was used. They have a huge bulk drum of the Mobil 1 LV fluid (or AC Delco HP version). What happened was the service tech used an old part number. So I was undercharged a bit bc the M1 fluid is more expensive. He said I could come in and have the invoice updated to reflect it or they will have it changed if I wanted to.
I will request a flush next time and make sure it's a flush and not pan/filter change. I'm glad the filter was changed though to get the OE wear metals out.
I want to stay on top of the ATF in this truck being they were prone to shudder issues. The 22's have a new torque converter which may or may not help. Time will tell.
There are some guys, even those with 2018's, that never have a problem. It's a very smooth shifting transmission. I like it a lot. I'm tempted to get the truck tuned as it could help prolong the life of the transmission.
The dealer closer to me said they normally use the machine and do a flush ($399). Rarely do they drop the pan. Interesting. The dealer I got the truck from said on the trucks they normally do pan drops.
Yes.
For more clarification:
TCC Shudder and New Mobil 1 Fluid Exchange
January 31, 2019
A new transmission fluid exchange procedure and a new formula of Mobil 1 Synthetic LV ATF HP transmission fluid have been released to address torque converter clutch (TCC) shudder conditions on 8L45 and 8L90 8-speed automatic transmissions
The TCC shudder condition is related to moisture content in the transmission fluid. The current fluid tends to be hydroscopic, or absorbs moisture, which increases the chance of TCC shudder. There are three different fluid exchange procedures to follow, depending on vehicle application, so that an acceptable concentration of the new HP fluid is achieved in the transmission.
The new Mobil 1 Synthetic LV ATF HP transmission fluid is now available to U.S. dealerships through your local GM Oil Distributor. The new Mobil 1 Synthetic LV ATF HP transmission fluid is available in quart bottles (GM Part Number 19417577) and, for a limited time, in 55-gallon drums (GM Part Number 19417904)
I did the diff fluid at 15k (replaced OE with Mobil 1) and ATF at 25k (pan/filter). I'm at 50k now. I keep the truck in L mode which locks out certain gears. Around town I keep it in L4 which blocks gears 4-8. Less shifting. On highway I keep it in L7 which at 75-80 mph the rpm is a nice 2,350.
