have a 2010 Denali 6.2L that just failed. got low oil pressure and checked the oil and it was about 3-4 qts low!!
Motor sounds fine, but oil had shavings in it and shop says motor has to be swapped. would try to run for a little while and see what happens but worried we will trash the block and wont have it for a core charge
Maybe has around 135-140K on it. Had the lifters and VLOM replaced at dealer around 90K and motor has been fine since.
oil pressure is sometimes only showing 5 at idle and only maybe 20 while driving, but then is going to 40 occasionally.
any thought son what failed or if it is even worth trying to rebuild?
