2008 Suburban 5.3, 154k. Changed the oil tonight. When I went to start it after refill, the gauge did not show any oil pressure. After about 7 seconds or so (felt like years), I knew something was wrong and turned the truck off. I tried it again quickly and still no pressure. I wondered if I had a filter issue so I removed the filter and put another on. No change.
It has oil and it’s apparently not a filter issue. Has the pump failed? Has the oil pressure sensor failed? All other gauges work fine. Any idea why draining the pan would cause something to change?
