This engine was sitting on the floor at my friend's shop. The CEL (check engine light) was on for a long time before they noticed some strange noises and rough running. The vacuum pump had failed, which triggered the CEL, but they ignored it for a few weeks. Bad mistake. The vacuum pump finally grenaded, which ruined the cam, caused the cam to slip timing, and ruined the motor. My friend does quite a few of these GM vacuum pumps, as they are a bad design and tend to fail. The owner ordered a new engine from GM, which was way expensive. The job with the new motor and labor is $9k. The owner also neglected doing oil changes and you can see lots of varnish and some sludge. The last picture is a shot down the intake running looking at the build-up on the intake valves, this is a direct injection engine. This much build-up in 70,000 miles.
In the next bay over was a Honda Odyssey, which was sludged badly and was using oil, lots of oil. Another victim of the owner neglecting to do oil changes.
End of camshaft that drives the vacuum pump
