Gloves for Working in 240v Electrical Panel... Safely
Central Texas
I've done a lot of my own electrical work over the years, including projects requiring permits having to be signed off by inspectors. What I've never done is wear gloves designed for electrical work. Now that I'm getting older, and the hands aren't quite as steady as they once were, I'm thinking I should take safety a little more seriously and get some gloves designed for this type work. I want the gloves to be as flexible as possible, but provide enough protection for an inadvertent brush against a hot circuit. It'd be more likely I'd hurt myself jerking away vs from the actual shock. All single-phase work limited to 240v panel voltage.
Please let me know your recommendations. Thank you.
I worked for the local power company many years ago.
Lineman wear a thick black rubber glove that goes half way up to the elbow and then has a large round red rubber bead at the end. and an extremely large leather glove over that to physically protect the rubber.
Both the rubber gloves and the leather gloves are inspected and dated and only allowed to be used for up to one month from date of inspection.
To inspect the rubber gloves, they are clipped to supports, and filled with tap water as they are submerged up to about an inch of the red rubber thick band built into the area around the opening. Then an electrode is placed into the water inside the rubber glove, and 10,000 Volts is applied between the water in the submersion tank and the electrode in the glove. If even a minute hole exist, current will flow, and the glove is then destroyed. If no current flows, the glove is dried and packaged in pairs in big yellow envelopes with the date of inspection on it.
The leather gloves are inspected for damage and holes and thrown away if damaged, or packaged in a dated envelope if good.
So, even if you bought Lineman rubber gloves and the required big thick leather protective over glove from McMaste-Carr, it really should be properly tested on a monthly basis, or sooner if damage is suspected.
Another thing that can be done is to use what is called a crowbar. Basicly, totally shorting out the wiring and also shorting it to Gnd. There's different ways to do this depending on what your dealing with, and even when properly applied, a crowbar, may only protect you from having the power turned back on and remaining on before you work on it. But, may not be enough to prevent you from being electrocuted. It only takes milli-amps across a human heart to kill a person. So, while a crowbar is a good idea, its not a guaranteed of protection. Still, many use them, and in different forms for different applications. Sometimes its clamped on and very heavy wire with very heavy clamps are used. Sometimes a heavy cable or chain is thrown over a dead bare power line.
Their not always used. But they do have their place to help improve safety. The idea being that sure, you checked that the power is off before you start working on it. But if somehow the circuit was to become hot while your working on it, a crowbar would trip what ever brakes or fuse that feeds it. It might save you, it might not. Power should never come back on to a circuit being worked on. But theres people killed while working on circuits. It happens.
Another thing to keep in mind, only one 120 VAC side of the 240 should be used per area / floor / room, what have you. When I worked at the power company, there was a worker there who used both sides of 240 to make two 120 outlets in the same room. He then used both for Christmas tree lights, got shocked and killed by those lights. If he had not put both sides of thar 240 in the same area, he may have not been killed.
Better yet would be all of one side ( 120 ), of the 240 per floor AND GROUND FAULTS ON ALL CIRCUITS THAT HUMANS INTERACT WITH.
Yea, its time to pull the meter, before you work an anything in the house. And take it inside and put it someplace where no one can get it and put it back while your working inside.
Some electric companies have their own seals, and now days, the meter may notify the power company if its pulled.
I have an electrician friend who just pulls apart the wire and plastic meter seal with a player's, and puts it back together after he puts the meter back.
#1 thing I hope you’re wearing is safety glasses. I’d also look into getting insulated tools.
Is it possible to turn the power off? For work, I have thick rubber gloves with leather gloves that go over them. Dexterity is horrible and it’s always suggested to turn off panels if possible.
I think those lower class 500 volt rubber gloves are yellow, and the leather protection gloves are also not as heavy and thick as the higher voltage rated gloves.
All of ours were yellow but I remember seeing some red ones . Yeah , the protectors were thin leather . They bumped us up to a Class O glove that was rated for something like 5kv . Pain in the butt to wear on low voltage work .
