Originally Posted By: Al
Many many years here on BITOG there was a lengthy discussion about GL-4 vs GL-5. At that time a very respected poster indicated that there was no longer equipment to certify GL-4 specs. He indicated (as I recall) that there was no problen any longer with corrosion of higher EP GL-5 products (used in GL-4 applications) due to their improved chemistry. I thought that poster was Molakule..but I could be wrong.
The whole discussion ultimately went nowhere. I would certainly like to know the answer to this question, "can GL-5 oil be used where GL-4 is specified?"
There are other threads that explained this very well.
First, some review:
Manual Transmission Lubricants
Second, let's dispel some myths.
The GL-X rating defines the protection level for gearing, whether it be transmissions, TC's, or differentials.
A
GL-5 rating is for highly-loaded gears (high tooth contact forces), such as for hypoid differentials, and contains high levels of primary and secondary Extreme Pressure (EP) additives such as Sulfur-Phosphorus chemistry. The viscosity of said GL-5 gear lubes is usually higher than for manual transmission lubes. For example, a 75W90 GL-5 gear lube has a viscosity of 18.5 cSt@100C, whereas a GL-4 protection rated 75W90 Manual Transmission lubricant would have a viscosity of 14.0 cSt@100C.
This difference in viscosity can have a major impact for Manual Transmission shifting performance in terms of cold weather shifter fork movement.
A GL-4 rating is for lower loaded gearing such as for manual transmissions (MT) and Transfer cases (TCs) in light trucks and cars. It contains mostly an Anti-Wear additive (AW) in the form of ZDDP or an equivalent anti-wear package. It does not contain Extreme Pressure (EP) additives. Furthermore, the GL-4 chemistry for MT's contain specialized friction modifiers for the synchronizer assemblies.
The GL-4 Performance Improvement package (additive package) has been tested by the additive suppliers to perform to GL-4 protection levels using modern testing machines.
For manual transmissions that share the same
sump with hypoid differentials, such as the Subaru drivelines, a special GL-5 lubricant is used which has the synchromesh friction modifier.
But this is an exception.
If your vehicle specs a 75W90 for your manual transmission or transaxle, these MT lubes should work just fine:
Amsoil MTG or Redline MT-90.
So the answer is, NO, not for Manual Transmissions.
