GL-4 75W-80 PSA Standard B71 2315 vs B71 2330
Eire
Hi Guys,
What is the difference between the two gear oils, i.e. PSA Standard B71 2315 vs B71 2330? Both are GL-4 75W-80, required for my 406 HDi. But they meet different norms and I can't find which one is more suitable for my transmission.
At the moment the box is filled with this oil:
http://www.lubs-products-database.total.com/gallery/ORIGINALS/visuels/23500/23664
And this is the alternative I am considering:
https://www.ravenol.de/en/products/usage/d/Product/show/p/ravenol-getriebeoel-psa-sae-75w-80.html
Google
1) PSA B71 2315.......and you will get results for MT gearoils.....GL4 etc
2) PSA B71 2330.......and you will get results for gearoils with GL4+ MIL-2105D...etc specs....thats more like GL5 oil.....as described above....MORE suited for transaxles...
Most probably ( IF you read MolaKules topics) GL5 fluid will not shift properly in any MT!!!!
Did you know there was also a FuelEfficient B71 2310 category? Factory Fill and "backward compatible"...
https://www.mobil.com/English-FI/Passenger-Vehicle-Lube/pds/EUXXMobil-Gear-Oil-FE-75W
Looks like B71 2315 is B71 2330 viscosity-wise with better base oils.
XOM is the FF supplier now and if you bought the oil from the dealer it would be Mobil Gear oil 75w-80 or FE 75w in the typical Mobil Bottle (the price at the dealer might be lower than the parts store's...yep.Check there first).
I do not think Ravenol is officially PSA certified.
So:
B71 2330 - Mobil Gear oil 75w-80* ; Total Transmission BV 75w-80** (newer TRANSMISSION GEAR 8 75W-80) ; Shell SF 5288**
B71 2315 - Shell Spirax S4 G 75W-80**
B71 2310 - Mobil Gear oil FE 75w*
* Factory -Fill with official approval and commercially available nowadays.
**Approved and commercially available . Have been used as FF and/or service oil thru the years.
I would not hesitate using any of the above products.
In older gearboxes I'd stick to 75w-80 (B71 2315 or B71 2330) viscosity and change @ 60 K km.
P.S All these have been API GL-4+ oils. Sometimes the vendor will list them as either GL-4 or GL-5 in the PDS ...or just omit the API rating(as is irrelevant. The only spec that matters in this case in the PSA approval).
Offtopic -Similar thing can be seen with ELF gear oils for Renault vehicles(Listed either GL-4 or 5 ).And there are multiple 75w-80 oils with probably different friction characteristics for the various Renault gearboxes (can't just get any ELF 75w-80 and use it...).
Actually the Mobil website lists Mobil Gear 75w80 as specifically GL-4 only.
Thanks for your comments.
It looks like a B71 2315 oil would be just as good as a 2330 oil. There is good availability of the Total Gear 8 oil, but I thought I would try something else, so I am looking at the Ravenol product as I have good experience with their engine oil.
