Quote:
Author’s Note
After reviewing the key formulation challenges expected with ILSAC GF-5, it is interesting to note
that the use of organo-molybdenum compounds is a recurring theme, as they are beneficial for
fuel economy, wear control, deposit control, oxidation control, and dispersancy retention. For
companies that manufacture and market molybdenum and organo-molybdenum compounds,
ILSAC GF-5 is indeed better late than never.
Quote:
Author’s Note
Quote:
Fuel Economy and Friction Modifiers
A formulator may choose to increase the friction modifier level in order to achieve the required fuel
economy increase in the Sequence VID engine test. Many friction modifiers are antagonistic
towards Cu/Pb bearing corrosion in the Sequence VIII engine test33. Certain organic, vegetable
oil-derived friction modifiers are aggressive towards lead34. This effect will be exacerbated in GF-5
if ZDDP is lowered from 0.075% to 0.065%, as ZDDP is a good metal protectant and helps to
protect Cu/Pb bearings from corrosion. In this case, other additives can be used to passivate the
Cu/Pb surface35,36. Certain molybdenum friction modifiers can also be corrosive but, unlike
organic friction modifiers, molybdenum compounds also bring strong oxidation, wear and deposit
control benefits to the formulation37
http://www.rtvanderbilt.com/ILSAC GF-5 Development.pdf
