getting started- air lift springs on 06 tundra
Southeast
Based on discussions in this bitog thread here (http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=3080483#Post3080483)
I've started picking up the parts necessary to add air springs to my truck. Thanks for the discussion earlier.
Ordered these:
http://www.amazon.com/Firestone-W2176022...tundra+air+bags
(this is the same p/n listed by firestone for the 2wd, so it should fit)
install looks straight-forward enough.
The cheapest onboard air controllers start at $120 and look pretty basic. For less money I can build something that does the same thing and doesn't vent the bleed air into the dashboard.
This pump, which will get stripped and mounted under the hood.
http://www.amazon.com/gp/product/B002L146OC/ref=oh_details_o01_s00_i02?ie=UTF8&psc=1
It's pretty small. I'm sure it's a cheap-o like everything else. I'll make sure it works on a few tires of course--- but it's run-time once installed will never be very long. so as long as it's half-decent, we're good.
This 12V solenoid for bleed-off:
http://www.amazon.com/gp/product/B00A15FT0A/ref=oh_details_o01_s00_i01?ie=UTF8&psc=1
I'll plumb in a pressure gauge sender with a gauge in the dash. I have one sitting around which will get the job. It reads to 100psi--- likely I wont need more than 50, but it's what I already have and should be close enough for starters. this is the gauge...
http://www.amazon.com/Sunpro-CP7001-Spor...s=sunpro+gauges
The pump, solenoid, and line to the bags will be a simple run with each component branched off a "manifold" of a couple of brass T's. a relay to drive the pump, 2 momentary switches and the gauge in the dash. a fuse or two. Done.
I've thought about valving for extra line for inflating tires. maybe in the future. there's still a budget...
I've also thought about adding a ~1/2liter reservoir (2" steel pipe with caps) to give me a little headroom in case of small nuisance leaks and as a buffer during pump-up, but I don't know if its really needed. Thoughts from any engineers out there?
Mike!
