- Joined
- Jul 10, 2022
- Messages
- 3,674
I won't lie--I looked at them, and even though I've purchased 4 fronts and 4 rears, I reused the ones on the vehicle, and nothing happened...Yeah, I'd like to see the engineering behind why something like a caliper bolt should be single use? Its clamping two flat surfaces together... Shouldn't need to be TTY as there's no penalty to being slightly overtight? Headgaskets, pinch bolts, sure you can get a more consistent tension on TTY bolt, and overtight can be bad.
Are these TTY on the caliper? just to save a few grams going down a bolt size and shaving a few grams off the caliper and hub?
I've purchased from this seller so it's a legit dealer
Maybe there is thread locker from the pic
Lexus LS430 (2001-2006) OEM Genuine FRONT BRAKE CALIPER BOLT KIT x4 90105-14151 | eBay
2001-2006 Lexus LS430.
www.ebay.com
