GON
$100 Site Donor 2024
Funny picture- but in all reality the Germans do outstanding engineering/ design.
Well … Wranglers have that much attached to a Dana 44 LoLFunny picture- but in all reality the Germans do outstanding engineering/ design.
I was thinking the same thing.Well … Wranglers have that much attached to a Dana 44 LoL
Or to have that compliant ride, great handling, big tires, and somehow still get a tight turning radius for parking.I remember looking under my 5 series and thinking how complicated it looked. However, I've never driven anything that matched it's ability to be a big comfy motorway wafter and then when required, pull it's socks up and annoy hot hatches in the twisties.
Yep, if you want to try to do it all, its not going to be simple!Or to have that compliant ride, great handling, big tires, and somehow still get a tight turning radius for parking.
I'd love to post those diagrams at my son's 4th grade class. It wouldn't surprise me if 1 or 2 boys can explain what's going onThe above image looks like the rear suspension set-up in my MB W210.
How about my flagship toyota saying per factory to replace all caliper bolts when doing brakes? They're like $10-$15 each. Last I checked the car has 4 calipers and each takes 2 bolts. That's pretty dumb, isn't it? I think picking on Germans is simply stereotypical. Some parts are multiples cheaper for a 7 series BMW than they are for an entry level Lexus.I've heard it said..."If you need 4 screws to hold something together, the German's will use 10 screws".
A lot of manufacturers require replacement of the caliper mounting bolts when servicing brakes. There is a long list of “one time use” fasteners for every car model.How about my flagship toyota saying per factory to replace all caliper bolts when doing brakes? They're like $10-$15 each. Last I checked the car has 4 calipers and each takes 2 bolts. That's pretty dumb, isn't it? I think picking on Germans is simply stereotypical. Some parts are multiples cheaper for a 7 series BMW than they are for an entry level Lexus.
Could you even imagine, a person having brakes done at a Lexus dealer? They'd have to be wealthy. It would be comical to know what is charged for front brakes. $60 alone in bolts, and another $120 in wear sensors. Almost $200 and haven't even gotten to anything of substance yet lol
It's one of the single most important parts. Could you imagine a rusted brake arm. Perhaps their was a cheaper way to the same direction afterwords.I read once that in an effort to save costs on an MB assembly line, the engineers were asked why the brake pedal arm required 5 coats of paint.
One of many examples is Ford's published requirement to replace the bed bolts securing a bed to a pickup truck. I think very few people to replace the bed bolts when installing a Ford truck bed. I actually cover bath the bed bolts in never seize. Those OEM bed bolts cost well over $100 retail. Dorman sells a bed bolt kit for $60 on Rock Auto for Ford Trucks.A lot of manufacturers require replacement of the caliper mounting bolts when servicing brakes. There is a long list of “one time use” fasteners for every car model.
Yeah, I'd like to see the engineering behind why something like a caliper bolt should be single use? Its clamping two flat surfaces together... Shouldn't need to be TTY as there's no penalty to being slightly overtight? Headgaskets, pinch bolts, sure you can get a more consistent tension on TTY bolt, and overtight can be bad.How about my flagship toyota saying per factory to replace all caliper bolts when doing brakes? They're like $10-$15 each. Last I checked the car has 4 calipers and each takes 2 bolts. That's pretty dumb, isn't it? I think picking on Germans is simply stereotypical. Some parts are multiples cheaper for a 7 series BMW than they are for an entry level Lexus.
It may not be TTY - it may be threadlock. Volvo stipulates that caliper mounting bolts are one time use - and the new ones have thread lock on them.Yeah, I'd like to see the engineering behind why something like a caliper bolt should be single use? Its clamping two flat surfaces together... Shouldn't need to be TTY as there's no penalty to being slightly overtight? Headgaskets, pinch bolts, sure you can get a more consistent tension on TTY bolt, and overtight can be bad.
Are these TTY on the caliper? just to save a few grams going down a bolt size and shaving a few grams off the caliper and hub?
Makes sense, so you could get some highish temperature thread locker and apply it to re-use your bolts.It may not be TTY - it may be threadlock. Volvo stipulates that caliper mounting bolts are one time use - and the new ones have thread lock on them.
Porsche also requires replacing caliper bolts, but interestingly theirs do not have thread locker on them, at least the OE's don't. I just did brakes on one of ours and replaced the bolts; figure Porsche has their reasons and do design a nice car and $40 added to the parts costs for a safety critical item is cheap insurance.Makes sense, so you could get some highish temperature thread locker and apply it to re-use your bolts.
