genuine honda ATF for $5 a quart?
North Carolina, USA
I've read online and heard from a couple people saying that Idemitsu actually makes Honda ATF. The bottles look identical and was just curious if anyone knows. I found Idemitsu ATF on on ebay for $5.05 a quart which seems way to cheap to be actual Honda ATF.
https://ebay.to/2p9UgKR
I wouldn't chance it. I've gotten ATF for around 9 a quart delivered off of ebay. Dealers think that stuff is made out magical unicorn farts.
Idemitsu ATF and Honda ATF DW-1 are not identical, this has been discussed on here quite a bit. The fluid in your link is not "genuine Honda ATF".
They may manufacture the Honda fluid but Idemitsu does not claim their branded fluid is licensed ATF DW-1.
Just what I was looking for, thanks for the helpful information. I was under the impression that since they made the ATF that the fluids would be identical! Glad I asked before I bought it.
That's still kind of high. You can generally get DW1 for $90 delivered for 12 quarts in the CONUS.
I too was under the impression/assumption that if Idemitsu made the DW1 for Honda that their version should/would be identical, or close. That's just not the case. I do use it though and it is working fine. The thing that swayed me is conversations with a well regarded Honda Trans rebuilder. His opinion that clean fluid is much more important than a specific fluid for longevity. He doesn't use DW1 in his rebuilds as evidenced by the 55 gallon drum of (I can't remember what it was, it was a flavor of multi-use ATF) in his shop.
If you will sleep better at night, use nothing but Honda DW1. There's enough evidence around that given proper maintenance one of the 'substitute' fluids should serve you well. (MaxLife, Idemitsu, AISIN, Etc.)
I paid $45.21 Canadian (11% sales tax included, so about $40 pre-tax) at my dealer for a 4L jug of Honda Type 2 coolant and 4L of the Honda ATF-DW1. At current exchange rates, about $31 for both. So that's under $5/US per quart.
So buy your supplies in Canada. The ATF-DW1 even says "full synthetic" on the bottle in Canada.
Considering I can't even buy generic fluid, let alone something labelled "full synthetic" (or implied, like licensed Dexron-VI) for that cheap anymore at the typical retail stores... Seriously, call your dealer and actually get a price before assuming that the stuff is a ripoff.
Even if Idemitsu Type H was/is the same, it's supposed to be for now Honda superseded Z1 or as Honda sometimes called it, Honda "Premium" Z1.
Based on H+ VOAs findings, I seriously doubt Type H the same as Z1 either.
Idemitsu H+ is supposed to be for the current DW1 fluid spec, but as shown it is not the same as the latter. Not saying H+ not fine to use as replacement, but not identical to DW1. It seems as though some like to pay a price premium for the name on the bottle and the implication, erroneous, that it is the same as DW1. Or, perhaps it's the "single use" application moniker that gets them to pay more.
Another tell, when Z1 is now superseded by DW1 by Honda, why is Idemitsu still selling the topic "H" fluid? H+ should be all that's used by Honda now. Doesn't add up.
So, while topic fluid (or Type H+) may very well be fine for use in your Honda, I wouldn't go under the assumption that because it's supposedly made by same company that makes Honda ATF, it's identical.
I ran Valvoline Maxlife atf in our old 08 CRV. 180K at trade in with no issues. That transmission speced DW1.
There are drastic differences in the composition of DW-1 and H+ and I have to ask, "why?". Why does Honda formulate it the way they do ? I have to presume they have good reason. They aren't in the business of making big money selling ATF so it's not done to trick people into thinking they have to use DW-1 and Honda has 'em by the spheres. In the grand scheme of things, it would be more cost-effective for Honda to use Valvoline Maxlife or some Dexron-based fluid. But they don't....
Simple - Z1 is still perfectly acceptable for use in Hondas pre-20xx (??). Honda doesn't want to produce and/or sell (2) different fluids for logistical reasons.
Any blender should be able to clone DW-1 if they chose to. At first I'd think maybe it's patented but I'm quite sure it's not. Then it could be a chemist asks "why in the world does Honda use that much 'x' ?". From a chemical standpoint, they would have an idea what it does.
Do we think Honda has figured out a miracle blend of ATF? If Honda is so smart, why did they make so many horrible automatic transmissions...?
Quote
Differences previously noted multiple times, in multiple threads including several VOA threads. As for why, as I don't use it, couldn't care less. Point was/is as topic indicates the OP was given the impression some how/way, Type H could well be the same.
Quote
Logistical reasons? So you have reference source for that being the case? In any case', "if" Type H was the same as Z1, highly unlikely, it's now been succeeded by DW1. Type H would be completely unnecessary now with Type H+. Only possible advantage if significantly less expensive than the latter for older Hondas.
Quote
Any blender should be able to clone DW-1 if they chose to....
Point missed. Point is it's proven H+ even though it seemingly implying it's same as DW1, it's not. I just didn't want the OP to think he's buying Z1 or DW1 under another name. Seemed clear to me.
All that said, Idemitsu Type H for Honda likely fine as spec'd by them, same for H+. Just as MaxLife MV at ~$18gallon has worked fine for me in a couple Honda applications 150k+ anecdotal mi.
I posted this over in Mola's thread as well, but I'll put it here since it will probably get more eyes/discussion. Short of it is, I emailed Idemitsu a while ago for clarification on all the things we've discussed about their H+ over the last year or so. This is their response (Bold text done by me):
'Hello, Shawn
Thank you for reaching out to Idemitsu Lubricants America Corporation.
Your concern is important for us, so we requested our technical department to provide additional information.
The DW-1 fluid requires specific properties (for example, viscosity, viscosity retention, low-temperature viscosity, etc.) and dynamic and static friction beside standard transmission oil properties.
Taking into consideration these aspects, we would like to share with you a comparison between DW-1 and Idemitsu ATF Type H Plus:
[Linked Image]
As you can observe in the chart above, Idemitsu ATF Type H Plus meets all the key performance properties for DW-1. Also, the static and dynamic friction performances for Idemitsu ATF Type H Plus are almost identical to that of DW-1 fluid. Each transmission fluid developed by Idemitsu undergoes strict quality testing to meet the exact frictional requirements as prescribed by the automaker.
In addition to the above, we would like to reemphasize that Idemitsu ATF Type H Plus provides several other benefits that meet and exceed the average requirements of ‘standard market' multi-vehicle transmission fluids, such as:
§ Enhanced fuel economy and superior low-temperature flow properties
§ Smoother shifting and outstanding anti-shudder performance
§ Excellent resistance to oxidation and thermal breakdown of oil
§ Superior cleanliness
§ Advanced anti-wear performance
§ Excellent seal compatibility
We understand there has been some open and passionate discussions related to the elemental analysis for DW-1, Idemitsu ATF Type H Plus and some market general multi-vehicle transmission fluids. We truly appreciate open discourse and productive feedback when it comes to the quality and performance of our products—it's the one thing we take most seriously and are proudly confident about.
Once more, we would like to reaffirm that the Idemitsu ATF Type H Plus uses a different additive package than DW-1—however, this has no bearing or impact on the formulation's ability to meet the prescribed performance properties for this particular transmission.
We hope the shared information will help clarify any doubts. Should you have any further questions, feel free to reach me via e-mail.
Best regards,
Thomas Khondaker
Product Manager, Aftermarket Oil
(Contact Details Omitted)
Imo the Idemitsu reply, reads like excellent promotional material. However, doesn't change that while the viscosity properties are similar, multiple VOAs have proven elemental analysis of the two, DW1 and H+ are not the same. That's just repetition in this thread and others.
That said, again doesn't mean H+ doesn't work just fine in the DW1 applications, just that it's not identical to DW1. Which was the OP's question. Of course his link was to Type H which was for Z1 now superseded by Honda.
I suppose if one is looking to be sold on H+ purchase, the reply might get that done.
A big concern to me is the lack of Zinc in the aftermarket fluids like Valvoline MaxLife, Idemitsu H+, and Castrol IMV ATF, also missing is magnesium too....
Molakule states that the Zinc in the OEM Honda DW-1 is critical for optimum operation and longevity of Honda style automatic transmission units.
Here are the chemical additive numbers
Label - Idemitsu Type H-Plusâ„¢ (Part # beginning with 30040090-):
Boron - 30
Silicon - 2
Sodium - 3
Calcium - 265
Magnesium - 2
Phosphorus - 245
Zinc - 3
Viscosity@100C - 5.91 cSt
Original Honda DW-1â„¢ (Part # beginning with 08200-):
Boron - 272
Silicon - 4
Sodium - 3
Calcium - 353
Magnesium - 204
Phosphorus - 2
Zinc - 320
Viscosity@100C - 6.93 cSt
Can Idemitsu, Valvoline, and Castrol address their lack of use of Zinc and Magnesium and why it would be OK ?
Idemitsu would likely respond to that if asked. It did take them a couple weeks to answer my first inquiry though, so it takes a bit of time.
You have the correct contact e mail address would you mind sending that question to them and bring back the reply? Thanks friend!
Imo Idemitsu has already explained their difference in add pack bolded in the reply posted: ..."however, this has no bearing or impact on the formulation's ability to meet the prescribed performance properties for this particular transmission." So they've made it clear, for them having an identical add pack is not a requirement for proper ATF performance in Honda.
I'd say the many members like myself who have successfully used ATFs like MaxLife, Castrol Full Synthetic MV, Idemitsu H+ and others in their Hondas over significant anecdotal miles, would agree with, if not verify that statement. Also if one is to accept even a more detailed explanation from them, then other ATFs not only H+ would have to fall under the same reasoning imo. That said, not sure how Idemitsu could make it more clear and seems pointless to try.
Z1 like DW1 had a similar high zinc, next to nil phosphorus add pack too and it's comparison to other ATFs discussed well before the recent VOA comparisons. Long time member Jim Allen was afaik one of the first to do a used oil analysis on then Z1 for his Honda and I think his 2013 linked post on the topic is worth noting. I found it to be true as commented on at the time, and with significantly more anecdotal miles in the 6+ years since, even more so now.
https://www.bobistheoilguy.com/foru...-valvoline-max-life-dex-merc#Post2934186
