regarding the storage, i heard on the radio today that some **** stole some guys generator and left a running lawn mower in its place. so store it at least out of sight.
i don't believe in stabil anymore, not with 10% ethanol gas. 2 years in a row using it in the boats and the carbs would foul beginning of next season. on my newer carb on my 4-cyl which is easy to pull the top cover off, I had rust spots and corrosion in the bowl. The ethanol pulls in the moisture, the gas separates, and you get contamination in the bowl. Any steel parts in the carb will rust and that will wash off as sediment and foul the carb. Had that happen very often on an old snowblower which had steel welch plugs. I found the best approach on small engines is to get the gas out of the carb, and if possible spray something oily into the bowl and through main jet and idle circuit to coat the inside of the carb and prevent any funk from happening.
