BMW Dom
- Joined
- Oct 6, 2020
- Messages
- 2,408
Was that en e90 or f30? I didn't think I would have the metal skid plate.Yup, metal skid plate right in the center under the oil pan. It had 4 bolts I believe they were 15mm or 16mm.
Why are we talking about transmissions now?Doesn't Red Line recommend the 75W90NS for manual transmissions? They claim that the friction modifiers in most GL-5 fluids to help with diff engagement isn't good in transmissions.
75W90NS GL-5 Gear Oil
Designed for transmissions and transaxles - helps to slow synchros for easier shifting across a broad temperature rangewww.redlineoil.com
Mine isn't a limited slipSorry. Long day and I missed that part where you were referring to diffs.
For some reason, Red Line sells 75W90 and recommends it for diffs with their diff additive. However, they recommend using 75W90NS and that additive to fine tune the amount of slip for a limited slip diff. Might be worth looking up if that's an issue with your diff.
Limited-Slip Friction Modifier
Compatible with both petroleum and synthetic gear oilswww.redlineoil.com
Interesting.Actually switched my E90 over to the newer 75W85 front and rear. GL5 in the front, GL4 in the rear. Luckily have lots in the bottom of my box.
I've seen it on both a 2006 325xi E90 and 2011 328xi E91 (wagon) that I've done work on.Was that en e90 or f30? I didn't think I would have the metal skid plate.
Do I acutally need to remove that metal plate? I can't find any info on what size socket is needed to remove the bolts.I've seen it on both a 2006 325xi E90 and 2011 328xi E91 (wagon) that I've done work on.
Yes, you need to remove the metal plate, but it's very easy. It's just a small rectangular plate with 4 bolts holding it, and you don't even need to remove the plastic under shield to take it off.Do I acutally need to remove that metal plate? I can't find any info on what size socket is needed to remove the bolts.
Alright, thanks. I'm planning to do it next Saturday, and I'll post some pictures.Yes, you need to remove the metal plate, but it's very easy. It's just a small rectangular plate with 4 bolts holding it, and you don't even need to remove the plastic under shield to take it off.
Here is a pic from Pelican Parts, the silver metal thing is the skid plate. Looks like it has 6 bolts on this car, although the 2006 I worked on most recently could've been missing some bolts haha.Alright, thanks. I'm planning to do it next Saturday, and I'll post some pictures.
Well, I had to remove itHere is a pic from Pelican Parts, the silver metal thing is the skid plate. Looks like it has 6 bolts on this car, although the 2006 I worked on most recently could've been missing some bolts haha.
Yeah, it must be removed in order to access the drain plug. I guess you could probably use a suction pump and go through the driver's wheel well to access the fill plug but then you won't get all of the fluid.Well, I had to remove it
I thought about it, but I already removed the splash shield. It took me a good few hours. Rear differential was like 10 mins.Yeah, it must be removed in order to access the drain plug. I guess you could probably use a suction pump and go through the driver's wheel well to access the fill plug but then you won't get all of the fluid.
Yeah it's kind of a pain. I'm glad my car is RWD, less stuff going on in the front. Luckily my friend was helping. I make a deal with my friends that I'll do work on their car as long as they help.I thought about it, but I already removed the splash shield. It took me a good few hours. Rear differential was like 10 mins.
Haha, that's nice. When I was younger, my dad would do most of the work, while I would watch. Now, it's beginning to be the other way around, and I'm happy to do the work.Yeah it's kind of a pain. I'm glad my car is RWD, less stuff going on in the front. Luckily my friend was helping. I make a deal with my friends that I'll do work on their car as long as they help.
