Non hybrid cars with stop start typically don’t go through nearly as many stop start cycles as a hybrid, so maybe trying to solve a problem that doesn’t exist.So can newer cars with stop start engine be considered hybrids and benefit from this type of oil?
Mobil 1 ESP 0w20 goes in my 2021 Honda Passport J35Y6 GDI engine and following the MM I easily get the recommended 10,000 miles out of it.
I have been trying to get Chris to run the QS FS 10W30 back when it was likely GTL juice. Gokhan's calculation showed itHate to bust your bubble but that member ain’t a teibologist. You avoided my question so worry about your own post “count”. You make hundreds of threads about almost the same thing. I cut oil filters open from many vehicles. There is NO BEST OIL period. Provide facts for your assumption please. Don’t worry about my factual posts either. No one “hates” you either. So, please act civil.
Thank You
The MM has no idea what oil you are using and would just as easily go to 10,000 miles on olive oil as Mobil 1 ESP. (Assuming the engine survived, of course…)
Not sure but you want low Ash look at Triax European line you knew thatWhat about ash?
The MM has no clue what oil you put in. What does a used oil analysis say?Mobil 1 ESP 0w20 goes in my 2021 Honda Passport J35Y6 GDI engine and following the MM I easily get the recommended 10,000 miles out of it.
Thank you for allowing me to clarify, the MM does not get down to 0% before 10,000 miles when I use this specific oil. With others it will get to 0% between 8000-9000 typically. Perhaps there's something to it? It's just speculation and it makes my brain happy![]()
GDI engine owners : Let’s hear what your oil choice is and especially what your OCI is ? I’m particularly interested in anybody with a GDI engine who exceeds 5K miles for an OCI ?
might be 2.65% VM which is about half Quaker State's 5W30 formulation. This stuff ran exceptionally well in my Ford that has D.I. and in Winter to boot. Even saw a long term average fuel milage increase. Last batch I ran didn't do as well so I moved on. Don't know if they stopped using GTL or it was just a typical base stock interchange - or the weather and my mood, lol.
Some believe SOPUS at one time passed on additional GTL capacity onto QS for Quaker State Ultimate Durability . It could have been temporary or it could have sporadically continued - we will never know .I have been trying to get Chris to run the QS FS 10W30 back when it was likely GTL juice. Gokhan's calculation showed it
