Hi,
Ted I am amazed that Amsoil still needs to continue "the sell" on BITOG with self interest threads! Their products are as good as most other Oil Company's products I'm sure - aren't they?
Redline, Shell, Chevron, RP, EM, Castrol-BP and others don't see the need! But they read on here!!!
It is really tiring and sadly at times the mis-information seems to exceed the "sell" - I often wonder if the inexperienced poster here sees through it all!!
Self interest threads self started by you - an Amsoil Dealer;
"This recent data caught my eye as I was looking at some of the recent GC, 0w-30 analysis results ....
ASTM D-4172B, Four Ball Wear Test
40kg pressure @ 150C, 1800 rpms for 1 hour duration
Amsoil 0w-30/TSO..........0.00 mm
Amsoil 5w-30/ASL...........0.00 mm
Syntec, 10w-30...............0.00 mm
Mobil 1, 5w-30................0.00 mm
It wasn't even posted where it should have been!
And then this;
"I answer a lot of emails and Private Messages about these two formulations, so I thought I'd try and clarify this question a bit. This is the most recent data I have on the "ASL" and "ATM" formulations:
---------------------------------5w-30-----------10w-30
HT/HS viscosity------------- Cp----------- Cp
VI----------------------------------------------
Noack Volatility----------------------------
CCS viscosity @ -30C------ Cp
CCS viscosity @ -25C--------------------------- Cp
Shell Four Ball Wear Test--0.40 mm--------0.00 mm
(40kg/150C/1800 rpms for 1 hour)
As for misinformation - grab this;
"Running a xw-40 is TOTALLY UNECESSARY in this motor - regardless of what VW recommends in their TSB. As long as you use an xw-30 that meets the ACEA A3/B4 and VW 502 specification you'll be just fine. VW is mainly recommending 5w-40 since this is an "idiot proof" way to go."
DH - Ted - "...regardless of what VW recommends in their TSB." This is very Cavalier of you Ted and I suspect simply a dangerous opinion that could be misinterpreted by readers on here. Where are you facts?
Very few xw-30 oils are actually certified A3/B3-04 - Are Amsoils range? And are any officially Approved to VW502 and others??
Do you know many xw-30 oils that are and that are available in NA?
Perhaps it has a little to do with "minor" things such as the HTHS vis. and the results from millions of miles of user experience and the results of the VW502 tests! For your interest the VW 2.0ltr engine is a good test bed - it produces known results via in-service experience and tests. It is the same as MB using their OM2?? to 6?? (diesel) specific tests and the API using the Cummins L10/M11 tests - tests on engines with known service and warranty histories! Some of these engines had design issues that cost purchasers millions of dollars and caused the API and others to react with improved quality standards via producer/user consultations and helped to form ACEA - thank goodness
Ted..................................!
And this;
"One thing I wanted to add is that the VW 502 spec uses the venerable, 115 Hp/122 ft-lb, 2.0L, non-turbocharged engine for the actual testing. There is NO testing in any of the newer, multivalve or turbo engines made by VW/Audi. So you can argue that this isn't the spec to use to determine the suitability of an oil for these newer applications."
DH - Ted you may chose to argue! The 115hp 2ltr VW NA engine has "a history" and like it or not IT IS THE TEST PROTOCOL! The facts are exclusively with the blokes who designed and produce and manage the engines through their production cycle. They have to handle production quality and millions of warranty issues on various components - in vehicles sold in various countries and not only NA! So you can argue - but without data and facts to support it your argument is "dead in the water (or oil)" I expect!
Then this;
"In other words, there is some correlation to valve train wear in an actual engine. Before anyone points out that engines don't use ball bearings, I suggest you do some research into the accepted practice of using analog tests throughout the field of materials science and mechanical engineering. You will find they are used all over the place ....For example, the Four Ball Test is required as part of the Mercon V transmission spec."
DH - Ted please come clean about the correlation of the "Amsoil standard 4 ball test for engine oils" (discounted by most other Oil Companies) to valve train wear! This is a MUST SEE for all posers on here! It most certainly has great interest for me - my valve train(s) include bearings and chains and hydraulic actuators and.....etc!
Strangely I have never had a need to consult a 4 ball wear test chronicle - and I have never ever had excessive valve train wear problems either in over hundreds of millions of kms. And even when using Delo and Delvac and RX Super and Rimula and others - and not Amsoil!
Now, I wonder why the 4 ball test may be required for an ATF - perhaps it's because of all the ball bearings in there.......................Ted!
At least Molakule got his four balls into perspective! Use the cheapest mineral oil and a few drops of AW additive and bingo - we pass with all four balls intact!
Regards
Doug
