6901 miles since last oil/filter change and 20,378 total miles on this '23 Ford Brocno Outer Banks with the 2.7L V6 engine. This is this Bronco's 2nd run/3rd oil change with M1 AFE 0w-30 after running its first 5000 miles on the facotry motorcraft 5w30 syn-blend fill.
Viscosity right at the bottom of the 30 range, but since this is energy conserving oil I suppose it's engineered that way. Wear metals are looking good to me considering the vehicle is right at 1 year old. The M1 AFE Ssems to be doing pretty well; this OCI mileage was mostly a two-way road trip through Northwestern Canada between Alaska and Washington with some gravel/dirty roads. Fuel was whatever was the most cheaply availble except I used a Techron Complete Fuel system cleaner/fuel additive at the beginning of this OCI. Oil filter was a Fram Synthetic Endurance cartridge type.
I've used up all the M1 AFE 0w30 I bought earlier this year so I guess I need to decide if I'm going to keep using it. I guess I don't see a compelling reason to switch. Add pack numbers are a little erratic (low Phosphourous?) but I guess I shouldn't worry about that too much. Running the 0w30 since it's an Alaska based vehicle, although could probably go to a 5w if I wanted since it's mostly started from a heated garage and this part of the state only gets to about -10F on a regular basis, with occassional stints into the -20's.
