Gas station 10w-40 conventional
eastern WA
Suppose I want to be able to just run any old 10w-40 in a hod rod with a roller cam. Aluminum heads, hyd roller, holley, headers, you know the deal. Don't rev any higher than 6000 rpm, change the oil once a year after no more than 2500 miles.
Why not just run a cheap 10w-40 syn blend and top off every now and again at a gas station with generic conventional 10w-40? What do you really gain by running something like VR1 or a premium synthetic?
CheezWhiz
eastern WA
I genuinely did not mean it as click bait. I have a pretty sweet 65 GTO with a fairly fresh engine. I've run VR1, Rotella 15w40, and 15w-50 Mobil 1.
It's been using some oil and I am playing around with the PVC system and tracking down leaks. I just want to be able to stop at a gas station and throw a quart of generic 10w-40 in it without feeling like I am throwing crappy oil in with really premium stuff. So I figured why not just run a cheaper 10w-40 anyway?
Muncie, Indiana
I'd use whatever 15W40 HDEO you can find, just because most of the HDEO you find has manufacturer specs for extended drains in diesel engines so you know it's good oil, 10W-40 on the other hand likely carries no manufacturer approvals and only carries the API S rating and doesn't have to meet meet the stringent criteria of the newer ILSAC ratings that have brought great improvements to the cheapest Xw20 and Xw30 oils over the last few iterations. Any gas station will probably have quarts of 15W40 for around the same price as 10W40 when you need top up and likely they meet several manufacturer approvals or at very least to claim CK-4 they have to have passed the T15 oxidation test
CheezWhiz
eastern WA
This response is exactly why I posted the question. Easy enough!
Eastern NC
I'd avoid any no name oil from gas stations because a lot of them don't actually meet any standards are just junk. Other than that if you want run any HDEO or I like the Maxlife 10W-40 suggestion.
CheezWhiz
eastern WA
If most gas stations are going to carry a brand name 15w-40, and that seems awfully likely, that probably makes sense. I will have to poke around in some gas stations. I am thinking of doing some cruising in rural areas where little mom and pop gas stations predominate.
Cincinnati, OH, USA
That's what I put in my brother's Chevy 1967 283 SB stroker motor, flat tappets & all, with a little extra ZDDP additive thrown in (Rislone, Driven, etc.). Any name brand 10W40 would be WORLDS better than the rubbery VII loaded ones of the '60s & '70s, remember bouncing sludge like an oily super ball...
CheezWhiz
eastern WA
I don't remember! I ran 10w-40 in the mid-90's in a flat tappet 350 Chevy without issue. I do kind of like the idea of a 10w-40 because I want to use the car in colder weather, I don't like waiting for summer. I've heard of Pontiacs shearing the oil pump driveshaft roll pin from too much pressure, so I guess if i can get away with a 10w-40 I'd prefer it. But maybe those sheared roll pins were on engines running 20w-50 on cold days without any warmup and high pressure pumps, I have the standard 60 PSI pump and drive sensibly until the car warms up.
Ruidoso, NM USA
p
carry a quart in the trunk of whatever quality oil you have in the sump.
Crap gas station oil worry…SOLVED!
South Carolina
I would at least use a common oil brand and avoid the gas station brands. Many of them are a rip-off with no additives and usually not in grade.
CheezWhiz
eastern WA
I'm kind of leaning toward checking out some gas stations to see what their inventory looks like. If I am seeing plenty of SN spec 10w-40 I probably prefer that to the 15w-40. Also I have a 4.0 TJ Wrangler and a 396 K10, I could run the same oil in all three vehicles and make my life a little easier. Free up some shelf space for more carburetors!
New Hampshire
Everyone needs ample space for dead corpses and ammo. Otherwise, what good is a car? Maybe a bracket under the hood that can hold a quart of oil?
CheezWhiz, thanks for making spilling the coffee on the keyboard. A good laugh indeed.
