When I had my VW GTI 1.8T, the oil always reeked of gas. UOA never found fuel contamination. Make of that what you will.I have gas in oil (smells like it). I looked up what could be and one thing was fuel injectors. So how can I test,see if that is it or part of it?
Maybe they never tested for fuel.When I had my VW GTI 1.8T, the oil always reeked of gas. UOA never found fuel contamination. Make of that what you will.
I just went back and re-read the used oil analysis (from '05-'06). The used oil analysis listed fuel as 1% in the 1st sample and 0.5% in the 2nd. I never did another UOA on this car. But the oil always smelled like gas.Maybe they never tested for fuel...
I bet they gave you some value and never really checked it.I just went back and re-read the used oil analysis (from '05-'06). The used oil analysis listed fuel as 1% in the 1st sample and 0.5% in the 2nd. I never did another UOA on this car. But the oil always smelled like gas.
1999 Nissan Altima 2.4 motorWhat year/make/engine? Port injected versus direct is going to vary our responses.
My mistake.Used Oil Analysis.
My oil checked to be 4.2% gas (in the oil).
Although I could NOT smell any gas.
