Hey guys/gals seeing if you can point me in the right direction on this. My wife and I just moved into a new to us house back in October. We've been having issues with the pilot light on this furnace. Bear in mind the inside handler was installed in 1988. Since we've moved in we've had to replace the blower motor (inside) and capacitor (inside) (did it myself). Well we've had issues with the pilot light since day 1 meaning it goes out all the time and does not stay lit when I try to relight it. There is flame but as soon as I let off of the pilot to turn the switch to the on position the flame goes out. I have replace the thermocouple 4 times since October and they all exhibit the same issue, within a month I'm back at square one. I've tried cleaning the pilot light orifice and that helped the flame size dramatically, however, I'm at my wits end as I do not want to keep buying a new thermocouple every month. I've tried cleaning the old ones with steel wool and sand paper with no luck. I am very good when it comes to diy btw. My handler is a Janitrol unit. From my understanding the thermocouple puts out amperage as it is heated up and in doing so opens a valve allowing gas to pass to the pilot light. Should I be looking at the gas valve next and if so what do I need to meter?
