Okay, so it was like this...
I was lying in the bath, thinking about pistons going up and down (like you do) and how it be a great idea if someone could just invent a better piston ring...
And then it came to me in a flash! Why not have TWO compression rings, one sitting on top of the other but fixed in such a way that their gaps didn't overlap. You would at a stroke eliminate the single biggest source of blow-by gas. Not only would you make the engine more efficient, you would get rid of the thing that does most to degrade engine oil. You would also get less carry-over of oil into the air intake so less oil consumption and less inlet valve deposits. The more I thought about this, the more ideas I had. You could have two rings of two different materials and tensions; maybe one optimised for suck and the other for blow. I was half way to writing the patent!
So imagine my disappointment when I got out of the bath only to find out on Google that gapless compression rings had already been invented. Bah!
But here's the thing. The only people that seem to be remotely interested in gapless rings are the racing fraternity looking to squeeze the last ounce of HP from an engine block. Given the automotive industry's obsession with fuel efficiency and reducing emissions, why aren't all engines built with gapless rings? Specifically why aren't GDI engines, with their various blow-by gas/engine oil related problems built with gapless compression rings?
I'm not a spanners and screw driver kinda guy so if anyone knows the answer, could you please enlighten me?
