It's well known that the early Audi 2.0L TFSI petrol engines were plagued with massive oil consumption problems.
There's plenty of evidence that engine oil could migrate from the crankcase of these engines back to the intake system to be burnt. I've also seen evidence that oil control rings would plug up with gunk and stick, exacerbating the oil loss problem from below.
Then I saw this video on YouTube...
https://youtu.be/G-WrxAOaWDs
This engine teardown shows that three of the pistons from an 2009 Audi 2.0L have oil rings which have broken into several pieces. I assume this only became apparent when the pistons were removed. Prior to this, I could imagine that the ring pieces were kept in situ in their grooves as a result of tension from the oil control ring spring.
I am genuinely puzzled as to why oil control rings would break in this way? It's clear from the filthy condition of the pistons that this engine has been burning vast quantities of oil. I did wonder whether this might be caused by oil burning related detonation problems causing the pistons to overheat but I'd expect this to cause problems at the top of the piston where pressures and temperatures are at their most extreme; not at the bottom where the oil control rings sit.
I suppose it could be duff metallurgy but it's just a simple piston ring; what's there to break or go wrong?
Anyone out there in BITOG-Land able to throw any light on this phenomenon?
